Kohler CH25S parts manual and/or exhaust bracket bolt
/ Kohler CH25S parts manual and/or exhaust bracket bolt #1
macindude
Hubertus, WI
Simplicity Legacy
Hi all,
Does anyone have a parts manual for the Kohler 25hp on the Legacy? (CH25S-68583) I can't find one online, there's just a bunch of parts sites and none of them list the part I need which is just a simple bolt that I need the size of. It goes into the block so I can't take it to the store and try a bunch either...
FWIW, it's the two bolts that hold the exhaust bracket. #6 on the Exhaust Group page. It'd be great if someone could tell me the size, even better if you can hook me up with a parts manual so that I can find the next one on my own. FWIW, it's bigger than a 3/8" bolt from my hardware stash...
Thanks!!!
/ Kohler CH25S parts manual and/or exhaust bracket bolt #2
The muffler may of come suppled by Simplicity not Kohler. so you will need the parts manual for the tractor.. Should have a 7 digit model number on a tag that will allow parts lookup for the tractor.
Odd. The Simplicity parts manual shows it but specifies a 3/8-16 x 5/8”. I took another 3/8-16 bolt and tried it and I’m able to just slide it in. Inner diameter of threads measured with calipers at 3/8” so it’s got to be slightly bigger somehow.
/ Kohler CH25S parts manual and/or exhaust bracket bolt #4
Looks like it could be M-839020-S M8X1.25X20 That is from the muffler kit for the CH25
Well, the immediate problem is solved. The 3/8 bolt Is for older ones than my 1997/8. The correct bolt is 7/16-14x1” per the tractor’s parts manual.
I still wish I had a parts manual for the engine.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2022 Bobcat T66 R-Series (A60462)
2022 Bobcat T66...
