Anyone have a clean way to drain the antifreeze out of a GC engine block?
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #1
rossn
Denver, CO
Massey Ferguson GC1705
The owners manual mentions annual coolant change, and directs you to a hose, which seems to only drain the radiator. Draining the block seems to require removal of a plug on the side of a block, but it's definitely a messy process as the coolant runs down the block, axle, frame, and everything else in the vicinity.
Is there a better way to do this?
GC1705
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #2
Any chance you could screw a threaded fitting with a short hose on it to redirect the flow, the plug is probably a pipe thread. Even if not, I imagine you could find a fitting that will lightly thread in there temporarily. Is there a possibility to replace the plug with a small valve of some sort for future changes? Use a shop vac to pull a vacuum on the cooling system while you play around with the fittings to stop leaking everywhere.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #3
Consider using the pink AF for anti-cavitation.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #4
Perhaps a lip made of RTV under the drain will allow a funnel to capture the mess? I will be trying this on mine soon.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #5
It's like changing the hydraulic oil, you can not remove all of it easily.
Pull the lower radiator hose, and that will get most of it.
What little is left in the block is still good anyway after only a year, and will be diluted by the new antifreeze.
The annual coolant replacement recommendation never made any sense anyway.
The thought of putting a valve on there is a good one, though it would be tiny, and would need to hold up to the heat OK. Similarly, I suppose putting some sort of nipple with a section of tubing and a valve on the end of that might be an option. However, that plug is super small... like 3/8" or less (I didn't take the time to check). Those approaches would need to be super robust, as I wouldn't want a failure from pressure/temperature/vibration that could lead to a fluid loss and overheating of the engine. The vacuum is an interesting idea, though the thought of fighting liquid and gravity.... I feel that might be challenging.
Mainly, I'm looking for a less messy way to change the fluid.
I was wondering if some sort of gasket funnel like you suggest might do the trick. Very interested to hear how this goes..
Any idea how much is left if the lower radiator hose is pulled? Is that less messy?
It gets me a little how the manufacturer engineers don't approach design considering orientation of oil filters or fluid draining from the vehicle. I think my car has the oil filter upside down.
Yes, the annual coolant change is a bit troublesome when non-diesels are now going a decade or more. All that I could gather from conversation here on TBN is that they are concerned about the additives leaning out quickly in the diesel engine. If it wasn't for the block draining mess, it could be pretty quick and easy.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #7
I remove the lower radiator hose and call the block good. What little that may be left in the block is not an issue with a regularly maintained system and the same coolant chemistry being replaced.
On many newer coolant systems there is the added benefit of not messing with the cheap plastic valve on the bottom of many radiators.
One of my diesel zero turns has a triangular piece of metal that is purpose built to deflect engine oil when changing the filter. It also has a metal petcock for draining the block coolant. Those are the ONLY engineered conveniences I have ever seen for coolant and oil changing.
Really though... It doesn't take much to hose the machine down when done.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #8
I usually pull the thermostat and flush all the old coolant and sediment out of the block and water pump with a hose after draining so everything will get rinsed thoroughly and immediately anyways so not long enough to dry and leave residue
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #9
It's a sub compact tractor. There simply isn't the room to do things the way we would like. Compromises are required.
There are also budget constraints on these. If they did it all the best way possible, it would be a lot more expensive.
Pulling the radiator hose is a little messy, but it drains fast once it's off, and it can mostly be contained with a drain pan.
The block isn't that big, what is left in there, and a little on the top by the thermostat, isn't a lot.
I don't change mine annually anymore, it just doesn't make sense. What comes out even after 3 years, is as clean as new. If it's a quality product it certainly lasts longer than a year.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #10
Anytime I want to drain and refill any cooling system, I drain and refill with water several times until I'm sure all the old coolant is gone. Use a little extra antifreeze when refilling to compensate for the water left in the motor.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #11
On my 1715 block/drain hose is right there on frame rail (plugged), how much mess can it make trying to use it?
I usually don't bother changing out AF fluids in any vehicles yearly I just check them to be sure the are up to doing what's required....
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #12
My suggest is to pull the bottom radiator hose off the engine side. Drain all the antifreeze that will come out. Reinstall the hose and fill with water run for a few minutes and drain again through the bottom radiator hose. Reinstall the hose and fill the the appropriate water-antifreeze mixture.
Stay away from if possible removing the plug on the block. Most diesel have wet sleeves in he engines. This is why it is recommended one use anti cavitation antifreeze made for diesels. A lot of piston damage can occur while you are trying to refill the block and get the air out.
"Most diesel engines are designed with replaceable cast-iron cylinder liners that are pressed into the engine block. While this doesn’t apply to turbodiesel pickups, it affects heavy-duty over-the-road trucks and other diesels.
The piston moves up and down inside the liner while a jacket of coolant surrounds the outside of the liner to cool the engine. When the engine is running, the pistons move vertically inside their liners several thousand times per minute.
Meanwhile, the rotary motion of the crankshaft applies a thrust force through the connecting rods to the piston. These contradictory movements cause the pistons to hammer the liners, causing significant vibration, similar to the effect of ringing a bell."
"This vibration can cause air bubbles to form in the coolant surrounding the liner. When the bubbles rupture, they direct a high-pressure stream of coolant at the liner. Like a rushing river carving away a canyon wall, the coolant can erode the liner until cavities form."
Anti-Cavitation Anti Freeze.
But if you do decide to remove the plug. Consider filling the cooling system with fresh anti freeze then loosen the block drain plug and either use air pressure at the radiator fill location or a radiator pressure tester until new anti freeze is forced out around the block drain plug. Remember the piston sit higher than the drain plug so you will have to insure the complete interior of the block is full.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #13
I'm in the "drain whatever comes out of the hose, pour in fresh coolant, and call it a day" camp.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #14
GC1705
I RTV'd a sheet metal lip under the drain plug that's just big enough to accommodate a funnel.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #15
Exactly what I do with both of my Large Frame Kubota M9's but I only change it once every 2 years. If your engine is a parent bore, no anti-cavatation additive needed. Only time it is necessary is on a wet linered engine FYI. Moat all late mode tractors are not wet linered. Either parent bore or dry linered.
If you aren't sure go to your nearest truck stop or truck dealership and get a bottle of Cummins DCA4 additive and dump that in with the AF. That takes care of any 'cavatation' issues you might have plus it mitigates cooling system corrosion and solder bloom in the radiator. I use it all the time and it's cheap, about 4 bucks a bottle.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #16
I always check my AF concentration with a Brix Refractometer. You can buy them on Amazon for about 15 bucks. I use it not only for AF but to check the coolant concentrations in my flooded coolant machine tools as well. Very accurate, I do not buy pre mix AF, only full concentration and mix it with distilled water ONLY.
   / Anyone have a clean way to drain the antifreeze out of a GC engine block? #17
They make test strips to check just pull a little out and refill if it is low use ell and be done with it also.unless
You run 1k to 2k
Hours a year waste of money
My tractor is twenty years old 368 hours changed once is still good after
The years no leaks no corrosion
But everyone gets to do what they think is right for sure
I also keep my unit in a garage
Makes all the difference in the world
Guys that let their units sit outside that are 3 to 4 Years old and look worse than mine. been turning wrenches for forty years on anything and everything. Just some time with a wrench🚜🤙
J and L Cargo Express Shadowmaster Enclosed Trailer (A56438)
J and L Cargo...
500BBL WHEELED...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
