rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,694
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
SNIP....
But definitely do the math before laying any tubing.
I agree with that. Math saves a lot of work. But floor heat can be different from traditional calcs.
When you start figuring how many BTU you need, give some thought toward the RATE at which heat moves in and out of different surfaces and through different materials. You can use math for rate of change calculations as well as for simpler sums. For floor heat, heat input can be very slow compared to outflow. That makes a difference, but the good news is that it will work even if you make a mistake. And is easy to change as long as there are enough loops of pipe in the floor to begin with. So err on the side of too many loops if you have any doubts.
Floor heat involves a lot of different surfaces and heat exchange steps. If doing it on the back of an envelope, I'd try to treat each transfer across a surface as a separate transaction, then estimate or calculate exchange rates as well as BTUs.
Do the math both ways, and think about the way that the "rate of heat transfer" will cause a floor heat system to differ from forced air heat calculations.
Another design difference to think about is that in floor heat systems, heat can be stored in a tank to be used later. That is something that is hard to do with warm air. HWH tanks are great for storing warm fluid.
And remember - no matter what you do, math is just a tool. Don't get hung up. Floor heat is great to have and will work in spite of mistakes in calculations. Floor heat is basically continuous parallel loops of warn fluid in and cold out - AND ANY AMOUNT OF BTU IS AN ADVANTAGE. All it takes is plumbing in two additonal valves to be able to accept heated fluid from any source. Doubling the input BTUs is simple.
A fist-sized silent Taco pump will drive fluid through several thousand feet of PEX tubing. In a low temperature type floor heat (the best kind) all the manifolding and valves can be standard plumbing fittings.
Most all the various ways to heat the fluid are safe, basic, and can be easiliy changed - so don't be afraid to experiment.
enjoy,
rScotty
