My 420 ft gravel driveway needs some attention. I am having some of the larger base material (#1 and #2 limestone) come up to the surface. I would like to know what course of action is best to get my driveway back into shape and be noticeably smoother when driving on.
From my understanding, the driveway was built by digging away the organic material until a solid base was reached, base layer of #1 and #2 limestone was used, followed by some type of fines material to lock it in place, and finally topped with #57 limestone.
I live in Ohio so winter weather and snowplowing does come into play.
The driveway is 4 years old and has never had a box blade or land plane on it. I had a local excavation guy take a look at it to see if a box blade or land plane would be better to performance some maintenance on it. He said both would be a terrible idea because all it would do is bring more of the larger base material to the surface. He said once that base material comes up, it will never go back down.
He recommended using a large and heavy ride on vibratory roller that will break up and crush the larger material that came to the surface. Then, a blade of some type can be used to smooth it all out. Followed by another round of a ride on vibratory roller to compact it. He said I have plenty of stone on the driveway already and no new stone will be necessary.
What are your thoughts on this?
Do you have a different approach to this project?
Pictures are below to hopefully provide a better idea of the current driveway conditions.
