Snow sticking to blade
/ Snow sticking to blade #1
Sierraau
Truckee, CA
2019 Rx7320
What do you guys use to keep the snow from sticking to the front blade? I've tried all sorts of products and they work for only minutes. I was thinking of sourcing up some hard plastic to pop rivet onto my blade face- perhaps that will help. Any ideas?
/ Snow sticking to blade #3
There are ceramic coatings that are readily available in auto parts stores ..even Walmart. .. Probably worth a try.
/ Snow sticking to blade #5
Early season snow I find can be this way along with a warm plow (in a building) that does a little melting and sticking later in the season with good normal snow that otherwise wouldn't stick.
Some guys wax or silicone spray the plow.
Edit; rockbad you beat me to it👍
/ Snow sticking to blade #7
usually early year problem... the blade is warmer then the snow, wax it maybe ?? cool it off with dry ice lol
Yep...early in the year our shovels and plows are warmer than outside (shed concrete holds heat) and the snow will melt/freeze to them. Later in the year, they are below freezing so I don't have the problem. I will use some tire silicone to help some. The problem goes away once the shed gets cold.
/ Snow sticking to blade #8
I use a wax type product called ProtectAll on my plows a few times per season with good results. Works very well on vehicle paint, windows, plastic, and rubber. On the tractor glass and mirrors everything stays clear.
It's marketed as an RV product, but I use it on everything... Including the iPad screen I'm typing on!
I live near lake tahoe, the snow is so wet and sloppy it sticks to everything. I've tried waxing my blade with a weed burner, and it lasts for an hour or so. I've tried several products- one (cant remember the name where you mix your one bottle with the other and paint it on in a pretty red color- looks good but no appreciable difference in snow stick; that's why I was thinking get some sort of heavy duty slippery plastic to bolt on as a cover (and keep my pretty new blade paint unskratched (just kidding).
/ Snow sticking to blade #10
Try some spray cooking oil, Pam or equivalent. Or just order a non stick blade.
/ Snow sticking to blade #13
If you are going to look at plastic coating then look at "slippry deck" liners for tip trucks.
/ Snow sticking to blade #14
You may as well invest in some slippery UHMW sheeting from Mcmaster Carr to bolt to your plow face with grade 5 ribbed grain elevator bolts and with the supplied nuts as you will be dealing with this problem every year.
They come with standard coarse thread nuts and you could use blue loctite instead of investing in nylock coarse thread nuts.
They should have both of these items in stock in their California warehouse and they ship orders on the same day they are received.
/ Snow sticking to blade #15
Exactly if you keep the unit in a shop or garage. The temp differential will always keep snow sticking to the blade until the temp equalizes. Fact of life and no coating or plastic will change that. It might help a bit but it will still stick a certain amount.
/ Snow sticking to blade #16
I bough a Bravo last year it was kept in a heated garage and the snow stick on the skis for a long time before like two months before it stop it was very annoying... I bought some ski skin but I am hesitant to put them on because they cause them to float too much and you get stuck regardless and it doesn't turn as good ... this year I will keep the bravo in the shade and outside see if it helps.
The tractor. is always outside, still a problem.
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
