Vermeer SC362 - Stuck Boom Head Lift Pivot Pin
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #1
arto98607
Southwest WA
Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
I have been checking my stump cutter for excess wear and found fair bit of slack in the "Boom Head Lift Pin" and bushings (Items 2. & 4. below), and would like to R&R the pin & worn bushings.
Problem:
The pin is stuck and has so far not budged!
I have removed the bolt and large nut (items 4. & 6.) holding the pin place, and have applied fair amount of heat to the boom head collars and tried to drive out the pin with a large hammer & brass pin, but so far the pin has not moved at all.
(The boom head is made of cast iron and will probably break if hit too hard)
Boom Head & Item 2. Lift Pin
Main Frame & Item 4. Bushings for Boom Head Lift
Question:
Has anyone here had to deal with this issue in SC362 and how did you get the pin to move without breaking the cast iron boom head (close to $500 part)?
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #2
A week of penetrating juice since you've tried heat?
I just happened across a "YouTube guy" that swears by heating the pin to a point where it'll melt candle wax and draw it into the friction points.....
I've never tried this yet but there's hope with optimism. 😆
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #3
Broco rod just need some
Oxygen and battery
Working on dozers don’t leave home without it
Have been spraying penetrating oil in-between heating & cooling it for over a week now, so far not helping.
I have been hesitant to heat the boom head collars lot more, but that I could do easily with a large oxy-acet torch.
Oxygen and battery
Sorry, cutting the pin with oxy-rod is not feasible without destroying the $500 cast iron boom head!
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #5
Keep beating then that’s what I always say
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #6
The other thing about cast is if you keep
Heating it it will actually shrink
So once you heat you need to hit it or figure out a press to work on it
I have shrunk quite a few castings so pin would fit tighter
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #7
Put freon on the pin and it'll drive out
/ Vermeer SC362 - Stuck Boom Head Lift Pivot Pin #8
When I put axle bushings in the dozers we used liquid nitrogen
It was like chemistry class all ov again 🤙
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
207275 (A52708)
207275 (A52708)
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
Volvo EC220EL (A60462)
Snap-On Zeus Diagnostic Machine (A61307)
Snap-On Zeus...
CFG Industrial H12R (A60463)
CFG Industrial...
