arto98607
- Joined
- Aug 27, 2014
- Messages
- 1,613
- Location
- Southwest WA
- Tractor
- Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
I have been checking my stump cutter for excess wear and found fair bit of slack in the "Boom Head Lift Pin" and bushings (Items 2. & 4. below), and would like to R&R the pin & worn bushings.
Problem:
The pin is stuck and has so far not budged!
I have removed the bolt and large nut (items 4. & 6.) holding the pin place, and have applied fair amount of heat to the boom head collars and tried to drive out the pin with a large hammer & brass pin, but so far the pin has not moved at all.
(The boom head is made of cast iron and will probably break if hit too hard)
Boom Head & Item 2. Lift Pin
Main Frame & Item 4. Bushings for Boom Head Lift
Question:
Has anyone here had to deal with this issue in SC362 and how did you get the pin to move without breaking the cast iron boom head (close to $500 part)?
Problem:
Question:
