John Deere 2030 replacement clutch kit?
/ John Deere 2030 replacement clutch kit? #1
Bob1969
Ford 3000
I am in process of replacing the clutch on a American made John Deere 2030 diesel with reverser. The problem I am having is finding the correct clutch kit for my particular tractor because there are multiple variations and every time I think I have the correct parts located I find them on a different site to be contradicting. My tractors serial number plate is long gone so that can’t be of any help but what I do know is it is a diesel with reverser with a 10” 20 spline single stage clutch. What I am opening for here is someone to throw me the correct part numbers for the clutch disk, pressure plate, throw out bearing and pilot bearing. Cost wise the JD dealer is not a option for me on this repair. I have the tractor split and the flywheel at the machine shop now just needing to find the correct clutch. Any help will be much appreciated.
Thanks a-lot TX Jim! I have a clutch kit on the way. I have one last question I hope, I will be installing a new rear crank oil seal and was wondering if there is any place the installation tool can be bought fairly responsible? I hate to spend big money on a tool I probably only gonna use once and I really don’t want to damage the seal trying to beat it in.
/ John Deere 2030 replacement clutch kit? #4
Have you attempted Goggling tool #? Have you considered asking local JD dealer service manager if dealer would rent you the tool?
So I have decided to bite the bullet and buy the correct tool but having trouble finding the correct tool. I have googled the heck out of this thing and just when I think I have found the correct tool It says in small print or in the reviews it wont work on the JD 219 engine or the DZ111672 seal. And I have asked my local JD dealer and they will not loan/rent the tool.
UNUSED FUTURE EXCAVATOR THUMB (A60432)
UNUSED FUTURE...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
207276 (A52708)
207276 (A52708)
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
6' FINISH MOWER (A60430)
6' FINISH MOWER...
