Thoughts on a pellet stove for a large shop
/ Thoughts on a pellet stove for a large shop #1
mx842
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I'm at the point where I need to put some heat in my new shop. I have plenty of wood that I could use but I am also looking at pellet stoves. I don't know much about them, but I like the Idea of being able to load up and not have to worry about it for a couple days. I'm not trying to keep it 85 degrees in there but would like to keep the shop 50/60 degrees so that my machines stay happy, and my pipes don't freeze.
It seems no one builds a stove that doesn't have a glass door on it. I don't care about looks or sitting around watching a fire burn, I just want the heat. I could build a stove and it may lead to that, but time is getting short, and my shop is still not all the way tooled up yet. I know I couldn't afford gas or electric and I don't generate enough used oil to keep a waste oil burner going so my options are limited. Just looking for ideas about the pellet burning stoves. The idea of not having to have a full-blown chimney appeals to me because they just vent through the wall.
/ Thoughts on a pellet stove for a large shop #2
Pellets are great but kinda expensive compared to free wood from your land. Ken Sweet
/ Thoughts on a pellet stove for a large shop #3
A lot of insurance companies won't allow wood burning stoves in shops. Vented gas/propane shop heaters cost less than a pellet stove. A lot of people are putting mini splits in their shops. They use way less electricity than resistance heaters and can cool and dehumidify too.
/ Thoughts on a pellet stove for a large shop #4
I like my pellet stove. I have found the bottom feed stoves to be more efficient. I buy a years supply of pellets at a time (3 tons) and this year with the price increase it’s at $250/ton (50, 40 lb bags).
Expensive compared to “free” wood, well free is relative. Tractor fuel, chainsaw fuel, oil, filters, drying time, stacking, restocking, stoking the fire. I open the bag, dump it in, vacuum out the ash and clean the glass every other week. :unsure: The blower and feed mechanism do need electricity to operate so they are on emergency power.
Depending on brand/model there are some rebates/grants/tax incentives to buy.
A pellet furnace may be more inline with your setup. The Harman PF120 hot air runs 120000 Btus @ 86% efficiency
/ Thoughts on a pellet stove for a large shop #5
Mini split’s might be a good option too
/ Thoughts on a pellet stove for a large shop #6
Pellets can be annoying to buy and store. 50lb bags would mean I'm the only person in my house that can feed the stove. And if i mess up my back, shoulder, knee, etc that takes a few days to recover from, that makes hauling those 50lb sacks a whole lot harder.
I have a wood stove, i cut wood on my land, i buy cord wood, and i buy wood bricks, depending on what's most cost effective at the time. Wood bricks are sold by the ton/pallet, they're the same thing as pellets, but in a brick form. The packs are 30-40lb which is easier to manage than a 50lb sack.
/ Thoughts on a pellet stove for a large shop #7
My neighbor solved the problem of being the only person in the house to handle 50# bags. Once a week during the heating season he dumps 5 bags of pellets into 10 5 gallon buckets. His wife can easily handle a 25 pound bucket of pellets when the stove needs to be fed while he's working 16 hour shifts.
/ Thoughts on a pellet stove for a large shop #8
I heat my shop with a classic wood stove but if I was in your location, I would seriously consider a mini-split. There are lots of DIY systems. If you have 220 volt supply to the building, the cost won't be much more than a pellet stove and you will get A/C as a bonus, which would be great for a shop in Virginia. Pellet stoves have kind of lost their popularity in our area now that pellets are over $300/ton here.
/ Thoughts on a pellet stove for a large shop #9
Is the shop insulated??
My shop is 57X45,, and up to 22 feet high,,
I modified a "Papa Bear" type stove to "SUPERCHARGE" it,,
That stove does almost zero towards heating my shop.
Two big wheelbarrows of dry hardwood (like oak),, will raise the shop temp maybe 10degrees F,,
My shop is all steel walls, but, I do have six inches of ceiling insulation.
I insulated the ceiling to keep out summer heat,, that was successful.
My stove mod was to create a lower chamber to allow the stove to have air fed under the wood.
It probably doubled the BTU output.
/ Thoughts on a pellet stove for a large shop #10
I know zero about a pellet stove, most of us down here in Florida that heat with wood just have a regular wood burning stove, never even seen a pellet stove but being able to load it up and leave it for a 24 hour period does sound appealing. I do know a little bit about DIY mini split heat pumps as the one I installed in my 800 square foot hunting camp has worked flawlessly, as someone else already said it might be a dealbreaker though if your ceiling height is really tall, if not look into them as it's really amazing how little electricity they use.
/ Thoughts on a pellet stove for a large shop #11
I've got a pellet stove sitting next to the Fisher stove that has heated our home for more than 30 years. It's not hooked up yet. I have a lot of ugly wood that needs burned up before I make the switch over. I'm looking forward to the steady warmth without so much tending. My plan is a bag a day just to keep the chill off. Sensible heat will still come from the main floor parlor wood burning stove.
I'm not looking forward to thinking about the $8 every time a bag of fuel is tipped into the hopper. It seems like over 50% of my wood burning fuel comes "free". (Not counting effort;-)
At present there is a LOT of fuel wood cut split and stacked, in the yard. If the pellet thing works out, likely four years worth ;-) Giving up the "trash burner" all winter is going to be another thing.......
/ Thoughts on a pellet stove for a large shop #12
Pellet stoves are expensive to run. Just how it is. If you have a free supply of cordwood it's still the best heating option out in the wilderness.
/ Thoughts on a pellet stove for a large shop #13
I have a pellet stove in the rental house family room…
Only one tenant has mastered it… some never tried and others tried and gave up…
My property manager asked what am I going to do about the 3 stoves that don’t work and I said enjoy them and sent her pictures of all 3 in use…
The pellet requires dry pellets, start up and then dialing in the dampers, adjusting the feed rate and blower and then periodic cleaning… evidently too much bother for 4 of the last 5 renters…
/ Thoughts on a pellet stove for a large shop #14
I’ve never understood the appeal to pellets. For what they cost you might as well burn propane and not waste time carrying it.
/ Thoughts on a pellet stove for a large shop #15
Good luck with finding a pellet stove that will hold enough pellets for two days burn.
After burning wood all my life I went to a pellet stove 4 years ago. Big learning curve. I bought a Harman P68 pellet stove after doing some research; it has worked out well and has one of the biggest hoppers (where you pour in the pellets) in the business. I believe it holds about 76 lbs of pellets - or less than 2 bags. It will empty that hopper in 24 hours on a "normal" winter day when it is not bitter cold. If it is bitter cold - 20 degrees or below - you can count on filling that hopper morning and night. There is a hopper extension available that will increase capacity but then you'll have to lift the bags of pellets really high to fill the hopper. Then there's the maintenance. Instructions for the Harman stove state you need to scrape the burn pot to clean it at least once a day. A more thorough cleaning has to be done weekly.
Only reason I went to pellets is that firewood is almost impossible to get around here; the last few years I was driving 480 miles (round trip) to buy firewood in Oregon. What firewood is for sale around here generally sells for $360 - $400 a cord.
/ Thoughts on a pellet stove for a large shop #16
Depends on the price of propane where you live. Here propane generally mirrors the price of regular gasoline. When you have to pay $3.60 - $4+ a gallon for propane (what it costs around here) then pellets are a good deal. Some of my neighbors who heated with propane last winter reported paying $500+ a month to stay warm.
/ Thoughts on a pellet stove for a large shop #17
Here's the maintenance required for my Harman stove. I believe most of the brands have similar requirements.
Wood stove requires a lot less maintenance!
/ Thoughts on a pellet stove for a large shop #18
If my calculations are correct it would take about 175 gallons of propane to equal a ton of pellets. That would make for a little bit of savings. Natural gas on the other hand is a lot cheaper than propane. At the national average price of $9.50 per thousand cubic foot it would only cost about $150 to equal a ton of pellets.
/ Thoughts on a pellet stove for a large shop #19
I heated my 2200 square foot house for 15 years with a pellet stove. They are a great option Figure one bag of pellets per 24 hours. They put out considerable heat , but will need fans to circulate the heat. Is your shop insulated?
/ Thoughts on a pellet stove for a large shop #20
Pellets can be bought by the ton at a cheaper price, but yes firewood is cheaper if readily available. Pellets are cheaper than propane or electric heating and more expensive than natural gas.
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2015 C&M TRAILER 14 ENCLOSED CARGO TRAILER (A60736)
2015 C&M TRAILER...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
