Yardmax track barrow anyone?
/ Yardmax track barrow anyone? #1
2manyrocks
Super Member
Any thoughts on this powered track barrow? I've watched a number of videos where people seem to like them for being able to move a few hundred pounds of rock or firewood over terrain that would be inaccessible to a tractor.
I've got an area where I will be clearing out some smaller trees with a chainsaw this winter. Not a lot of working room for my tractor, and there are a bunch of thorn trees so the rubber tracks would be great for avoiding flat tires. I'm thinking it would be handy to carry my chainsaw, gas, portable gas winch, ropes, etc.
/ Yardmax track barrow anyone? #2
I don't know, but I did look at the link you provided. While I didn't read the literature on this item, you may want to see how it turns. Do you have to force it, or does it have skid-steer type turning ?
Richard
/ Yardmax track barrow anyone? #3
I could see where it would be useful and should work as designed. In tight spaces it would shine but making sharp turns probably will be rough on the grass. They said zero turn in the description but it looks like just brake steering.
Looks like they may offer attachments for it as well. At least I saw a snow plow so there may be more? Let us know if you get one and how you like it.
It has independent brakes levers to control each track. The YT videos show it turning pretty easily like a mini skid steer as well as climbing over modest obstacles that would be a pain to push a normal wheelbarrow over.
I haven't seen other attachments for it besides the snow plow. I only saw one video of it being used in snow and the guy was carrying firewood in it, not plowing snow.
I thought about the hydraulic dump version which has 1100 lb capacity vs 660 lbs for the normal wheelbarrow one that has a manual dump lever + cylinder assist. I think the simpler version would be enough for me, but I could see someone getting the hydraulic dump if they plan on moving a lot of material with it.
Haven't really thought of what it could be, but I wonder if there would be something else that the hydraulic could be adapted to doing? Like a mini set of log forks? The carrying tub is positioned over the tracks so I'm guessing forks would get to be too front heavy? Why even lift the wood by hand into the tub if you could convert this thing to use a modest set of forks?
/ Yardmax track barrow anyone? #7
Here's is one I tested. Not me in pic.
What did you think? Useful?
/ Yardmax track barrow anyone? #10
From the web site. They have a video on there site
A Motorized Carrier for Those Difficult to Reach Areas
The LS360 Trailblazer Transporter, a motorized carrier by Orec, features a dual track drive and a durable metal bed that can take loads of up to 650 pounds anywhere you need to go. The independent wheels can cover steep slopes and obstacles with no problem—they can even handle steps! Whether you are a contractor needing to move materials, a land maintenance professional looking to clear a trail or you just need to haul material around your property, the Trailblazer will help you get the job done with little effort and maximum safety.
Haul Smarter with a Motorized Carrier
A common problem landscapers, trail builders and large property owners face when needing to haul heavy materials, is that they don’t have the right outdoor power equipment for the right job. Perhaps their equipment is far too large to transport materials through tight spaces and maneuver up and around obstacles from uneven ground and rough terrain to challenges such as steep slopes and stairways. This motorized carrier is not only versatile with its adjustable walls to accommodate a variety of loads, but the Trailblazer Transporter makes professionals look smarter by helping them haul smarter!
The Orec video sums up a lot of the content others have posted about using a track barrow. The yardmax is limited to R and 3 forward gears instead of the two range on the Orec. The Orec also uses a Honda where Yardmax has a Briggs. Yardmax has a version with sides that can be removed. I hadn't thought about moving lumber with it until I watched the Orec video. I imagine you could also move fence posts, too.
In terms of basic usefulness, a UTV would haul you plus your stuff where these track barrows only haul your stuff. But there's quite a difference between UTV pricing and the pricing of one of these.
/ Yardmax track barrow anyone? #12
I know folks used these to drag lumber and tools into bridge sites that they couldn't used an ATV for. Maybe not all that far but still easier than doing it by hand.
They don't seem to travel quickly, especially compared to UTV speeds, which can get pretty fast. So that is worth considering, too.
/ Yardmax track barrow anyone? #14
Per our other conversations...
PT425 10cu ft bucket - $700
PT425 5cu ft bucket - $560
PT425 5cu ft grapple bucket with teeth - $1800
About 35 other attachments.
I didn't see anywhere in the video that it went that the PT wouldn't go, and I'm pretty sure the PT would go more places. Only limitation would be width. Also, it loads itself and dumps better.
Again, not pushing it on you, just showing there's more than the brush clearing we talked about in the other thread.
Riding beats walking, especially if its a long distance uphill.
/ Yardmax track barrow anyone? #16
I like it. Seems reasonably price by today's hardware standards. And you'd be popular if you have neighbors or deer hunter friends...
/ Yardmax track barrow anyone? #20
Unless you are in very cramped quarters it seems like a one trick pony run by a lawn mower engine.
If you have enough space to use a Kawasaki Mule I can tell you mine has been bulletproof. It has an air cooled golf cart engine, decent sized dump bed and carries two people. The SX model I have lists for $7800 and comes with a three year warranty. It is a work UTV. Top speed is 25 mph so not great for trail riding with your buddies that have $20k toys. They will laugh at you. But we use ours to ride logging trails and it goes anywhere.
It is almost 4 times the cost, but it will do a lot more around the homestead. If I was going to handle logs I would add a large deep cycle battery and 3500 lb winch
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2013 Mercedes Benz GLK SUV (A64557)
2013 Mercedes Benz...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
