/ Share Pics of People Hauling or Towing Something Wrong #18,803
How? Spun off the road backward!
Tommy Flanagan
would probably say "I uh... didn't have a trailer hitch... so yeah, that's it, we put the trailer on the truck with a forklift and.. yeah the barn is right off the pic to the right, that's the ticket. Everythings! great! handles great!"
/ Share Pics of People Hauling or Towing Something Wrong #18,804
I cannot recall which towing thread taught me this lesson, but I wanted to thank the experts at TBN for saving me time and perhaps more.
I was towing wrong today. Had a SxS on my trailer and was going down the road. Got up to about 30 mph and it starts to wiggle. Even before TBN, I knew this was bad. Thanks to TBN, I knew exactly what was wrong and how to fix it. I was able to go about 25 until I got to a boat ramp. Pulled in there, loosened the straps and moved the load forward about 12-18 inches. (Retightened) Presto, no more wiggle, even at highway speed.
A hearty and sincere thanks to whomever (probably many of you) pointed out the symptoms of too little tongue weight.
There is a balance to it. Maximizing the load on the tongue can also have negative effect.
My Subaru Outback really shouldn't be pulling an open 16' tandem axle trailer, but when I have if a SxS is all the way to the front the butt of the Subaru drops and the rig porpoises on bumps.
A good balance seems to be to place the rear of the SxS over the trailer axles and then a fair bit is in front of the trailer axles.
The total here is just over 2000 pounds. Subaru rated to tow 2700 pounds.
/ Share Pics of People Hauling or Towing Something Wrong #18,805
Well that photo is much more "Hauling wrong" than towing wrong... But with the payload being a trailer, I guess it fits both categories! :oops:
Geez that had to be a ride!
/ Share Pics of People Hauling or Towing Something Wrong #18,806
Your tongue weight should be dialed in to roughly 10% - 15% of gross trailer weight. So, if trailer + payload happens to be 5k lb on a given trip, you should adjust the load to achieve 500 - 750 lb. on the tongue. Of course, most aren't going to have a way to measure trailer weight and tongue weight handy, so it becomes a bit of a SWAG.
The first time I loaded my tractor + loader + ballast + wagon all onto my landscape trailer, I remember playing musical chairs between the tractor, ballast box, and wagon, until I got the thing to balance right. After figuring it out once, you just repeat.
And when loading logs on my trailer, I've developed an eye for what's right, mostly watching how the trailer levels out under load. Generally, this works out by putting the center of each log length over the front axle of my tandem, when laying logs in length-wise.
This is very important at highway speeds, less so if you're doing 25 mph between two neighboring houses.
/ Share Pics of People Hauling or Towing Something Wrong #18,807
But you are citing rule-of-thumb numbers. Rarely do we have a scale to measure. Too many who read such instruction conclude the solution is to put as much on the tongue as possible.
In my cited example a trailer long enough for 2 SxS had only one parked at the very front. With a marginal tow vehicle that was far too much. When moved back so that much was over the trailer axles the rig behaved properly.
Likewise I have a purpose built very expensive Kendon Dual Stand Up motorcycle trailer. It carries 2 dirtbikes with ease behind the Subaru. But put (2) 650 pound Yamaha FJR1300s on it and we are back to porpoising. Moving one back a only a foot helped tremendously. Probably should have moved both back a foot. If I was to do it again I'd look into remounting the rails and wheel chocks.
/ Share Pics of People Hauling or Towing Something Wrong #18,808
Yep. They became rule-of-thumb numbers, because they're right!
Already noted. When setting up a new boat trailer, yes... I do actually rig up scales to dial in the position of the boat on the trailer. It's a one-time chore for years of towing that boat on that trailer. But no way am I doing that for each differing load on my landscape trailer, that is just handled by eye, and then adjusting later if it feels off.
Leads to proposing and potential understeer, by exceeding your vehicle's maximum allowable tongue weight.
Going for a level trailer is a good starting point, but that also relies on having the correct drop on your hitch and a tow vehicle with a tongue weight rating appropriate for the trailer. Likewise, if you know you're hauling ~5k lb, and you find you can lift the tongue, you're obviously too light. After that, feeling how it tows is the final metric.
/ Share Pics of People Hauling or Towing Something Wrong #18,809
If you have the vehicle for it, I'd argue more tongue weight is better. Look at a semi....lots of tongue weight there.
I've always done it by eye as well. Hard to even explain exactly how I get there, given the variable loads I've dealt with. Would be curious if I'm at 15% or if I'm way off. Never had sway, so I know I'm on the heavy side.
/ Share Pics of People Hauling or Towing Something Wrong #18,811
Has this questioneverANSEWERED
Here's an answer!
4x8 trailer rated 2k.
I weigh 180.
Had wife measure distance hitch to ground before loading, then measured it again with me standing on hitch. It settled some 3 inches.
Loaded the trailer, adjusted the carried cargo (unmounted bumper weights) - to get a little more than that 3 inch hitch deflection.
Easy peasy!
(Note everything here is nearly at, but not exceeding, rated capacity. Except there should be trailer brakes over 1k).
/ Share Pics of People Hauling or Towing Something Wrong #18,812
^^ Scientific method in action!
/ Share Pics of People Hauling or Towing Something Wrong #18,813
Here's an answer!
I weigh 180.
Easy peasy!
I love that you towed the Yanmar with the Outback.
/ Share Pics of People Hauling or Towing Something Wrong #18,815
160 miles, in 105 degree weather! Redding to home. Open freeway, no trafffic. Then next day, the additional 100 miles home to ranch. Rolling along with the slowest trucks went smoothly.
Then a few years later I finally found what I had searched for for years. Another YM186D (low enough to get under my orchard trees), this one with loader and the rare Power Steering option. And only 20 miles away. That tow was just over rated weight, but was slow and on back roads with no other cars.
p1730707rym186d2onhwy-jpg.368644
/ Share Pics of People Hauling or Towing Something Wrong #18,816
I really like my new Weigh-Safe hitch with the built-in scale, it takes the guesswork out of positioning on the trailer. I try for 10 to 15% of Gross Trailer Weight on the tongue. This trailer gross was around 13,000 lbs.
/ Share Pics of People Hauling or Towing Something Wrong #18,817
I love that!!!
/ Share Pics of People Hauling or Towing Something Wrong #18,818
I stand on the bumper or hitch of the tow vehicle, measure the sag, and knowing how much I weigh gives me a calibration. Then when trailer is hitched I measure again. If same sag as with me standing on the bumper then I know the tongue load is roughly my weight. If twice as much sag then I know it is at least twice my weight as the tow vehicle springs will be somewhere between linear and progressive.
But I don't worry too much about the 5%-15% tongue load thing. What is really critical is to not have a negative tongue load or for it to go negative on the road during bumps. Then the other thing is the mass behind the trailer axles. This is the mass which wags the dog.
/ Share Pics of People Hauling or Towing Something Wrong #18,819
I also have a weight-safe hitch on the truck - costs a bit more but it is a VERY well-made hitch and it takes any guesswork out of loading any trailer with any items, even the first time.
/ Share Pics of People Hauling or Towing Something Wrong #18,820
I really like my Weigh-Safe hitch but the only way I can read it is to do what you did, take a picture of it.
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2006 CATERPILLAR D6N CRAWLER DOZER (A62129)
2006 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
