Power Loss in BX2200
   / Power Loss in BX2200 #1
JWR
Elite Member
So MD / WV
MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I've searched other BX2200 power loss threads and found none matching my situation. This one has about 900 hrs on it. I've had it for 20 years. Garage kept. Nothing remarkable aside from being well kept for at least the last 700 hours and 20 years. Generally very reliable. Have fixed many minor things over the years (installed the hard start relay, replaced a few hydraulic lines, put in steering cylinder seals, etc.) but just a super all around work horse.
For many years it has had an odd thing going on where where I hear it change sound from the standard purr of a good little diesel to what sounds like it is laboring -- almost like an exhaust obstruction. Lowered pitch in frequency of the engine sound -- from a "yeee to an uuuh" if you can think of it with me,,, which of course I cannot describe well. But definitely slightly lowered pitch sound. Ignored it for many years. [Always when fully warmed up, running pretty much full throttle.] In earlier years I could not detect any loss of rpm or power. -- just the sound. Could not convince myself there was anything wrong. This season for the first season it has lost power noticeably in some of those incidents. Lower rpm, maybe 40% loss of power, but keeps running. When I reduce load (like shutting off the belly mower or stop pushing into a pile of soil with the FEL, reducing throttle , etc.) it hesitates a few seconds and picks back up to near full rpm but still does not sound quite normal. Shut it down, go away for 1/2 hour, come back and start it up and all is well with no apparent after effects. In the last week it has happened several times & mainly when under heavy load -- max output shoving full loader bucket from a pile and lifting, etc. all at full rpm. At least one of those times restarting gave stumbling and unhappy slow response in engine rpm.
Have used Seafoam additive over the years many times but generally I am not an additive fan. Get my diesel fuel at local automotive stations. Have used/maintained 5 other Kubota's (both 3 and 4 cyl) over the last 20 years and none of the others have this disease.
Any ideas what is going on here?
   / Power Loss in BX2200 #2
Failing fuel line from the tank to the primary filter maybe. I had to replace mine on my cab M9 this year. It was failing internally.
By failing you mean collapsing, air leak or ? Any way to test it or just easier to replace it and see if that erases the issue?
   / Power Loss in BX2200 #4
It was coming apart inside and pieces were partially blocking the fuel flow. I replaced mine with 'Tygon' fuel line instead of the OEM black whatever it is. Pretty easy to replace too..
  • Good Post
Reactions: JWR
Good info. Thanks.
   / Power Loss in BX2200 #6
Have you replaced the fuel filters? They are tiny little things a plug up easily, usually the rear one is the culprit.
I'm no doubt going to do that but it just doesn't seem to fit the known facts -- that this has been going on for years, never affected power output that I could tell until a couple months ago, goes away completely after stopping use of the tractor for a half hour, etc. Also why the sound would be the noticeable thing to change and be noticed when the problem occurs. For sure good idea to just replace them, but how do I explain that being the issue?
   / Power Loss in BX2200 #8
My 2003 BX2200 did the same thing. I replaced both fuel filters and it fixed it.
  • Good Post
Reactions: JWR
   / Power Loss in BX2200 #9
I owned a BX for 10years and had it happen also like you describe.
  • Good Post
Reactions: JWR
   / Power Loss in BX2200 #10
Mine wouldn't do it when I first started the tractor and ran for 1/2 hour or so. Once it got hot or I hit some tall grass it would do as you describe. It was the fuel filters, replace both of them, they're cheap to purchase.
If I'm right and it fixes your problem, you owe me a beer.:)
  • Good Post
Reactions: JWR
IRET13 ELECTRIC TRICYCLE (A58216)
IRET13 ELECTRIC...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
2010 International 7600 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2010 International...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Volvo EC220DL (A57148)
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
