58 MPG by 2032
/ 58 MPG by 2032 #421
Cylinder deactivation.
I love TPMS.
Ditto. I'm amazed anyone could dislike this feature. If I bought a car today without TPMS (is it even possible?), I'd likely install my own aftermarket. Same with backup cameras.
I love old cars. Heck, I used to own a 1939 Cadillac LaSalle, among several others. But I love new cars even more. No comparison on handling, horsepower, reliability, lower maintenance, comfort, convenience features, storage space... I could go on. Anyone looking at old cars with rose-colored glasses, while criticizing the new, surely forgets how much work old cars were to maintain in good running condition. It's hard not to admire a 2020 Hellcat or Shelby GT500, no matter what you think of their predecessors.
All of my modern 5.7L and 6.4L HEMI cars (I have three) have cylinder de-activation, but it's disabled with a button press. I push the start button, then the button to disable the cylinder deactivation, in that order, before pulling out of the garage. No biggie.
/ 58 MPG by 2032 #422
Show me a modern day engine that will go to 300k miles. Lots of 80's, 90's, and even early 00's engines make it well past 200k and with basic care, 300k. Adding complexity of all the crap they have added to increase mpg while maintaining power.
With twin turbochargers, no less. Oh, and he traded it fearing the transmission would need major service.
Save you 50 pages of posts, this is where it is said he sold due to transmission:
/ 58 MPG by 2032 #423
I'm not sure what is worse engineering wise... GM's cylinder deactivation (that causes the engines to burn oil) or TPMS sensors or the stop start feature. All bad in my opinion.
100% agree, if only mfg's would all make a deactivation button, to let consumers decide if they want their engines to last longer.
Cylinder deactivation has cost consumers countless wads of money. It is a crock of crap. I bought a black box to plug in for long trips for my Yukon. A buddy had to research for days, finding the right length lifters to do a cam/lifter overhaul.
Some folks I've known, wouldn't buy anything but a push rod engine, with good reasons. Now, the gov't has made it where they don't last.
TPMS is a pain, costing too much to keep up IMO. If it only cost $20 a tire to keep up every 8 years, it would be worth it.
/ 58 MPG by 2032 #424
Ford Godzilla 7.3L is pushrod. State of the art too.
Well, $30 is a high DIY price. Autel MX sensors are usually (4) for $120 at Amazon. Model specific OE-compatible sensors are less.
Friend's 2011 Ford went 11 years before one sensor battery failed, 2 reported weak, and 1 was still happy as a clam.
/ 58 MPG by 2032 #425
I love TPMS. I put aftermarket TPMS on my streetbike and on my trailers. Saved my butt many times on the streetbike providing early warning during a ride that the rear tire was deflating. Yamaha FJR1300 doesn't do bad things going straight until the tire is very deflated. I certainly do not want to enter a fast sharp turn with a half inflated tire as I'll occasionally drag a footpeg. I don't want to drag a handlebar.
I love TPMS so much I own an Autel TS-508. I know 5030 is really hating me now! The TS-508 is fun for being able to check tire pressure, non-contact. Don't have to bend over! Totally excessive! But fun! Impress Your Friends!
Neither my Tesla nor Subaru have TPMS PSI display. The lowly F-150 does. Tesla would add it for only $800, replace the TPMS module to the latest, update the software, and change the wheel sensors. Cool that they could/would do it, but not at that price.
The F-150 has ASS. Has an easy button on the dash to disable until the next engine start. Doesn't bother me most of the time but if I approach a traffic light that I think is about to change I hit the button. So far too lazy to fire up Forscan to turn it off by default. Doesn't bother me enough to make that effort and I don't know of anything I want to hack on the truck.
If you are having one flat tire after another, your doing something wrong.
Over the last 20 years, I have only one tire go flat, and that was a blow-out on my trailer.
Check your tire pressures and look at your tires.
Richard
/ 58 MPG by 2032 #426
I'm perfectly capable of using a tire gage and maintaining correct air pressure. Just had the TPMS sensors replaced on the wife's Burb to the tune of 160 bucks. Once one fails it's only a matter of time for the rest to fail. No frigging defeat sadly.
Holley makes a cylinder deactivation device that plugs into the OBD port but you can (at the expense of a check engine light) deactivate it by pulling the Molex connector on the power brake booster.
Later model GM engines require a major teardown to delete it.
All that stop-start crap does is wear out your starter anyway.
/ 58 MPG by 2032 #428
The Beetle has TPM without sensors in the tires.
I'm good with that.
It works via the ABS wheel-speed sensors. They sense when tire pressure drops, because the wheel roll is reduced and it turns more quickly at the same car speed. The system checks your tires constantly, keeping you safer
/ 58 MPG by 2032 #429
The 2 things that a lot of people NEVER check is tire pressure and windshield washer fluid.
And radiator fluid and trans fluid and gear oil and grease fittings and belts and hoses and oh! I'm getting carried away.:D
/ 58 MPG by 2032 #430
4 or 5 in 85,000 miles on street bike. Am very careful about where I put my wheels, crud at intersections, etc. Flats are always on the rear. 2 lane country roads. The porcelain slit was on urban roads.
Very few on my automobiles. One on Subaru while touring my property. Oddly I have only had one on dirtbike in 20 years but in races on the same trails with 150 or 500 bikes we continuously pull people out with flats. Tube tires go flat quickly. My street bike is tubeless.
One on Tesla. On 4 lane US-64. “Thump thump thump” big fender screw made noise. Quickly pulled over. Prepared plug kit. Took screw out, no air escaped. Splashed with water to confirm. Put plug kit away. Bought 4 new tires the next week. See photo below.
Radial tires are very hard to eyeball tire pressure.
/ 58 MPG by 2032 #431
That's the plug kit ? lol when I was a kid we ran dune buggies in the desert. I always carried an assortment of big sheet metal screws to plug tires with.
/ 58 MPG by 2032 #432
That was the thump thump fender screw I stopped to remove. Then no leak.
/ 58 MPG by 2032 #433
Is there a vehicle with cylinder de-activation, in which the driver can't disable that feature? I like big-displacement engines, so all of my newer cars have had cylinder de-activation, but also all easy to turn off. It's annoying that it turns back on each time you restart the car, but all turn off with just one or two button presses.
Me too. But I have to admit that hitting two buttons on my steering wheel to check it while sitting at a stoplight is even easier than busting out the tire gauge. When I had to do it old-skool, I'd set a reminder on my phone to check the tire pressure once every 3 months. But with TPMS, I probably check them once per week!
One thing people forgot both before and with TPMS, is the spare tire. People having flat spares has always been common, and spares rarely contain TPMS. Check your spare, folks!
/ 58 MPG by 2032 #434
Richard
That's true if all you ever drive is pavement. Some of us have to drive dirt roads. Rocks will get you every time. Some of the ranch and mine pickups around here carry 3 spares...the OEM under the bed, plus two mounted in the bed.
This is why.
/ 58 MPG by 2032 #435
True that -- I have not been on pavement since May. Fixing flats caused by our rocks is an ongoing endeavor. We run 10 ply on cars and at least 8 on tractors , 6 or better on ATVs. My feed wagon is on solids because I got tired of flats. Pulls like crap but the tires are up :cool:
/ 58 MPG by 2032 #436
The TPMS sensor sleeps when not rolling so the spare is problematic to check. They use a 125 kHz RF wakeup burst (simple CW) to wake a sensor without rolling. Same as the "TPMS Clicker" widely sold on eBay and Amazon. At a minimum this tool is needed to wake a new TPMS sensor from manufacturing hibernation. Put in a deep sleep during manufacturing to keep it from waking during shipping.
Proper TPMS scan tools emit the 125 kHz burst when one initiates a wireless read of the sensor so a separate clicker is not of much use.
Think some BMW and Audio Audi have TPMS in the spare. They must also have the 125 kHz to initiate a read.
/ 58 MPG by 2032 #437
Interesting point on putting TPMS to sleep. Wasn't aware of that, but it makes sense, as most are just using lithium or NiMH batteries, which do have a limited lifespan.
I also assume you mean Audi, and the spell checker got you there. Our Audi did not have TPMS in the spare, only the four mains, but maybe they've changed that in the last few years.
Only time I ever had a TPMS go bad was in our 2003 or 2004 Jaguar, but that car was in such a terrible accident shortly after we bought it, that a lot of things ended up failing. I've owned at least a dozen cars with TPMS, and it's been flawless in all of them, never a problem. The longest I've ever kept a car with TPMS was 12 years though, which does appear to be about the expected lifespan of a TPMS battery, so I could see buyers of older cars having to deal with battery or sensor replacement.
/ 58 MPG by 2032 #438
I don't think NiMH is used, only know of lithium.
Yes, many purchase replacement sensors on Amazon or eBay, DIY, then complain their vehicle never sees the new sensor. Some vehicles are capable of auto-detecting sensors but this is not 100% reliable, and if a new sensor is not woken from manufacturing hibernation it will never work.
Thanks! Fixed. Apple's predictive speller has gotten overly aggressive in "fixing" earlier words several words later in typing where one is no longer looking.
Likely not a feature of all models. Is not a common option.
/ 58 MPG by 2032 #439
I completely agree with the notion that private jets and other forms of conspicuous consumption don't set a good example.
I'll push back a bit on the use of the phrase "campaign vehicle". It's not that simple.
Our current sitting president was well known for using public transportation to commute to work when he was a senator. The massive vehicles that come with a full suite of communications equipment and security came with the job of president, and these vehicles are a requirement, not a choice. When he had the choice, the current president chose the form of transportation that consumes least fuel.
A president or vice president is *required* to use the vehicles supplied by the military and secret service, even on personal or campaign trips. However, when Air Force One is used for a campaign trip, the campaign must reimburse the Air Force for the equivalent cost of chartering a private jet. So the campaign pays for the basic transportation, and the taxpayers pay for the upgrade to vehicles that keep the president in communication and secure at all times. That's part of the job, not a choice, and there are reasonable rules in place around reimbursement for campaigning.
Source: https://www.npr.org/2016/07/07/485097272/fact-check-air-force-one-who-pays
If you're going to call politicians out for their conspicuous consumption, I'd say it makes sense to focus on those who, when not constrained by their work duties, *choose* to throw away fuel in a grand display of their wealth. It also makes sense to look at the number of personal or campaign trips they make while in office. I'll leave it as an exercise for the readers to assess who the worst offenders are by that measure.
I don’t think campaigning for other candidates around the country as necessary. It doesn’t matter if they have to pay the air force for use as you say, the waste and pollution is the same. Typical hypocrisy.
/ 58 MPG by 2032 #440
Watts is significantly different than Watt-hours.
When you cutsie slang shorten Watt-hours to Watts the meaning of what you are saying totally changes.
It’s still the standard of measuring for sale purpose.
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
INSPECTION (A65563)
INSPECTION (A65563)
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
Caterpillar 330BL Excavator Service and Parts Manuals (A63117)
Caterpillar 330BL...
