What have you done to your Branson today?
   / What have you done to your Branson today? #1,481
@Slowpoke Slim sorry to hear about your health issues, hopefully things get better.
You'd think there would be a lube to put on the plastic bowl filter so it wouldn't freeze up, but I can't think of what it would be. Wonder if diesel fuel makes the plastic swell up and stick like that?
I think a little grease on the threads would be ok. The plastic has to be a fuel resistant type so it should be ok with grease. It does seem to get a little sticky on the threads or maybe it's the rubber gasket. Being behind the loader mount and (on the open station) next to the operator platform makes it a lot harder to work with than it should be.
   / What have you done to your Branson today? #1,482
Ha! That will do it. At least it wasn't something loose between the engine and the transmission!
I think this is the correct part number: TA00054036A
I show TA00054037A for just the rod. I think your part number is entire assembly which may be the only way to get the rod. We will find out tomorrow.
   / What have you done to your Branson today? #1,483
That's it. I had the two open and ended up copying the wrong number.
   / What have you done to your Branson today? #1,484
Were are you guys getting parts besides the dealer?
   / What have you done to your Branson today? #1,485
I will get the part from the dealer. Unless you were asking where we get the part number? For that we downloaded the parts manual.
   / What have you done to your Branson today? #1,486
Yes I asked about parts themselves. Too bad it is impossible to buy them online
   / What have you done to your Branson today? #1,487
How about
welding it
File to fit
Paint to match....
   / What have you done to your Branson today? #1,488
Here is what I done to my Branson today : 🤣 :mad:
LOT: (2) Dewalt Electric Drills, (1) Dewalt Electric Grinder, (1) Milwaukee Grinder (A59076)
LOT: (2) Dewalt...
HELI 5K FORKLIFT (A58214)
HELI 5K FORKLIFT...
LOT: (100 approx.) Gallons of Transmission Fluid (A59076)
LOT: (100 approx.)...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
