Southernmfg bushhog oil seal replacement
   / Southernmfg bushhog oil seal replacement #1
Ky farmer16
Kubota l2900 and ford 1500
I have a 4 ft southern mfg bushog that needs a oil seal in the gear box but the problem is they are closed and don't make the. Anymore and I cannot find any information on them anywhere so I don't even know where to begin to k ow what kind of seal I need any help would be greatly appreciated it?
   / Southernmfg bushhog oil seal replacement #2
Take the old seal out. Take it to a store. Say here, I need a new one just the same size as this Problem solved. I have replaced thousands. NEVER bought one from the manufacturer.
   / Southernmfg bushhog oil seal replacement #3
Any good bearing shop will sell seals by ID/OD and type. So, along with the old seal, you may want to grab accurate diameters on the shaft and bore, before heading to the store.
You can sometimes get the old seal out with minimal distortion by drilling a small hole in the face of the metal case of the seal, and screwing a sheet metal screw partly into this hole. This can be used with a small nail puller or claw hammer, one on each side, to withdraw the seal with minimal distortion or damage. Just use a collar on the drill bit or choke it short in the chuck, to prevent overshooting into the bearing behind the seal.
Yhats the problem it dont have one or I would its the seal underneath where the blades ore when I first got it and put gear oil in it was just hemorrhaging it back out thats how I found out it didn't have one I've heard you can put john deer corn head grease in them but I would like to have it work the right way with a seal but I can't find one
I'm gonna get a micrometer and have to measure it I guess and go that route
   / Southernmfg bushhog oil seal replacement #6
Well, if you clean the metal casing of the seal reall well, you may find some identifying numbers stamped on it. So, you may not need the measurements, but always better to have them handy when you're standing at the parts counter.
I hope so ima work on it monday....they place that made the bushogs are no longer in business I'd love to be able to get new blades for it as well but can't find anything about it there is no serial number or anything on the bushog and I can't find anything about it on the internet
   / Southernmfg bushhog oil seal replacement #8
A lot of the blades are pretty generic for rotary mowers like this, so you may have luck finding an exact match thru Tractor Supply Co. if not, buy the closest thing that can be machined to match, and then throw a post up on the Practical Machinist forum. Plenty of freelance or moonlighting machinists there, who are happy to get an odd job like that.
   / Southernmfg bushhog oil seal replacement #9
Tractor supply needs help. Nobody in the ones near me know where or what anything is. Pitiful I tell you
   / Southernmfg bushhog oil seal replacement #10
As others have said, get ID of seal location in gear box housing and OD of the shaft also depth of seal housing........ Inexpensive digital calipers should be accurate enough....
Take numbers to good bearing supply house.... OR spend some time online (MCMASTER?)
   / Southernmfg bushhog oil seal replacement #11
WranglerX I agree with you 100 percent. That is a fool proof way. But my point is Tractor supply employees are not in tune with us who use this equipment. And you would be wasting your time to show them this.
   / Southernmfg bushhog oil seal replacement #16
I wouldn't even bother with TSC for a seal. Every town has a bearings and drives place. Their name will usually include "bearings" or "drives", or "gears". Here's mine: Frank Callahan Co., Inc. Colmar Branch Page
Now go find yours! These guys will take one look at your old seal, double check with your measurements, and give you the right part... all likely under $15.
24220 (A56859)
24220 (A56859)
2022 CATERPILLAR PM622 COLD PLANER (A60429)
2022 CATERPILLAR...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
