Southernmfg bushhog oil seal replacement
   / Southernmfg bushhog oil seal replacement #11
As others have said, get ID of seal location in gear box housing and OD of the shaft also depth of seal housing........ Inexpensive digital calipers should be accurate enough....
Take numbers to good bearing supply house.... OR spend some time online (MCMASTER?)
WranglerX I agree with you 100 percent. That is a fool proof way. But my point is Tractor supply employees are not in tune with us who use this equipment. And you would be wasting your time to show them this.
   / Southernmfg bushhog oil seal replacement #16
Tractor supply needs help. Nobody in the ones near me know where or what anything is. Pitiful I tell you
I wouldn't even bother with TSC for a seal. Every town has a bearings and drives place. Their name will usually include "bearings" or "drives", or "gears". Here's mine: Frank Callahan Co., Inc. Colmar Branch Page
Now go find yours! These guys will take one look at your old seal, double check with your measurements, and give you the right part... all likely under $15.
(2) Drums of Car Wash Brush Soap (A51573)
(2) Drums of Car...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2017 INTERNATIONAL PRO STAR (A52472)
2017 INTERNATIONAL...
Peterbilt 377 Semi-Truck (A53472)
Peterbilt 377...
