Brush Hog mods
/ Brush Hog mods
It is listed as either 1:1 (early model) or 1.25:1 (later model) gear ratio.
I ordered some gasket material last night. Then after sleeping on it. I ordered the shim at a great little Midwestern tractor supply that looks to specialize in discontinued parts. Very reasonable pricing too. In case anybody else needs them go here > Kubota | Bush Hog | Land Pride | Buy Direct | Order Online | German-Bliss Equipment
/ Brush Hog mods #122
These chain cutters really want a 1:1.92 ratio to keep the speed high. It will still work somewhat ok, just not to its full potential.
/ Brush Hog mods
I revised my reply - looks like it may well be 1:1 early model.
/ Brush Hog mods #124
Good Morning scootr,
Just finished reading the entire thread, great reading and interesting ! My valve cover on my Masset 1040 started leaking a couple of years ago, ended up just buying some gasket material from OReillys Auto Parts. Of course I wasnt dealing with any gears meshing properly to obtain the right amount of backlash ! Im guessing your bearings are all ok ?
/ Brush Hog mods
Always something, isn't it.
Murphy prevails ;)
Well, my friend told me that it works good. You just have to wear hearing protection because the blade tip hits the dented side a bit :oops: We fixed that when we cut the blades and added a bit less length of chain... we will find the answer to your bearings question in our test runs.
Gasket material coming today from Amazon.., More importantly there was a shim which I mistook for the gasket, maybe it did double duty... anyway - that is coming soon also. So we wait.
/ Brush Hog mods
Got the drive line seal today... hope to get the driveline out and the seal in sometime darn soon... this thing needs to hold oil! What a mess chasing these leaks.
/ Brush Hog mods #128
We are all patiently waiting !! 😉😁
/ Brush Hog mods #129
it’s only been 62 days. After the Body shop and paint, under lighting, touch up paint, assembling a video production crew, a couple of young actresses (+ stunt doubles), and the red carpet premiere, TBN release date is probably looking at spring of 2024 :rolleyes:
/ Brush Hog mods
Just received the new driveline seal yesterday. We plan to change this seal in the next couple of days. Oil is just pouring out of this seal right now.
/ Brush Hog mods #131
Hopefully the shaft isn't scored too, or you will have a bigger problem.
/ Brush Hog mods
We started installing a simple driveline seal. Pretty certain this thing has never been apart and rarely greased...making matters worse. U joint was a heck of a fight, so was the yoke and shaft. Everything went into the press ultimately.
Heavy and rusted - not fun. U joint clips rusted to death... broke when disturbed...have to find them now.
The shaft looked good and the seal was a good fit.
Weird U joints had no roller bearings by design. Cleared the grease passages of old hardened grease. Will try to find time to put it back together today - we'll see.
/ Brush Hog mods #133
But it will be a fantastic video!
  • Good Post
Reactions: D&D
/ Brush Hog mods
It works !
Will upload some pics here in minute
/ Brush Hog mods
Chain mower test.
Before and after
/ Brush Hog mods
Here she is in all her glory.
/ Brush Hog mods
It cut weeds, small trees, and broke rocks. Seemed to run best about 480-500 rpms ( I'm guessing) There was some unwanted vibration at full 540 rpm per my rpm indicator. So backing off a bit gave the same cut and mulch without so much vibration. The good news is there are no leaks! That seal was a biotch to replace.
She is a very solid tool. I dare the weeds to grow :LOL:
I'm using 70 grade 3/8th chain which did not show alot of wear in our little test. I think the harder the better on the chain. Nothing flew out the front so the curtain is working as designed. I may have had the mower a little low.
All in all we're happy so far.
/ Brush Hog mods #138
Glad its working out for you ! Looks awfully dry out there, maybe you should bring it up to Vermont and see how it works on our really lush and green fields !;):)
Anyway good to see you managed to fix all the problems with this unit ! Wondering how thick of a shim or gasket you had to use to get the proper backlash on your gears ?
Now that its working properly, you can paint it up pretty to match your tractor !;)
/ Brush Hog mods #140
I admire your persistence. Do you think you need to add some mesh to the ROPs? The ROW mower guys used to do that around here.
