Good morning!!!!
/ Good morning!!!! #175,801
55 high of 91 today maybe a storm maybe not
nice hoist PJ
Nice piece about ex BIL Drew
My allegories are in full force very dry here grass brown no mowing for us
Prayers for all our Country
/ Good morning!!!! #175,802
He warns those who have them to not leave them constantly plugged in once fully charged.
I wonder if anyone stands there and watches the charger. Seems the charger should know when a battery is charged. Most all the chargers I have signal when the battery is fully charged. You would think if the charger is smart enough to know that, then it should be smart enough to turn off. I think I'd be talking to my attorney about why a charger can start a fire.
Any way....
We're three days away from setting an all-time record for the number of days over 100 degrees. We'll most likely match that on Saturday. It's currently a balmy 73 degrees with all my windows covered in due. Thank God for air conditioning.
/ Good morning!!!! #175,803
Good Morning!
God has given us another chance to get it right (or at least most screw up too badly).
66F going to upper 80s, mostly Sunny,mchance of stray afternoon T-storms.
Went to periodontist for first follow up, mostly good report except for a 2mm tear over one of the teeth that will hopefully close up before next follow up mid-September. At least another week of smoothies and soft food. Yay…
before heading to perio appt, I repainted the top of an old metal toolbox I got at a theirt. Repainted the tray too. 8x7x16, heavy steel, new today it would be a $75 dollar box or more. Not anKennedy (no nameplate) but close in design and execution .
Last Night’s druggie house activity turned out to not be LE but EMS, someone went out on a bus.
Today is waiting on technician to come look at leak in the hot tub. Of course it is not on the side with the access panel…
While waiting on the tech, I will be applying linseed oil to all the tool handles - it is that time of year!
I also have to call up the Whirlpool help line and BMC at the, - when I was in Lowe’s, I had to call them to find out which type of anode I needed (plug or nipple) and was told it was plug.
it ain’t…
so I have to exchange and it is just another delay for a scheduled “quick” project. Yay…
maybe get the dogs up to the lot later, pick some tomatoes and cayenne peppers and fresh basil (the three things that are doing best in the garden).
I hope everyone has a happy healthy safe productive blessed day!
/ Good morning!!!! #175,804
65 outside this AM. It might get to 80 today. 81% humidity. Maybe some rain later, maybe.
Roofer stopped by, seemed enthusiastic. No issues with what we wanted done. Waiting on estimate and if OK, scheduling. Let's hope that works out. Looks like I will be tearing down the chimney after all. Need the space
inside anyway.
Not much on the agenda today. Maybe take the weed whacker for a walk.
Hope all have a great day. Be safe. Those with health issues, here are positive thoughts your way.
/ Good morning!!!! #175,805
Good Morning
It’s 66 with a high of 70 under partly to mostly cloudy skies today. 40% POP.
Yesterday was a beautiful day weather wise, a busy day for me.
The morning trip to the Vineyard went according to plan, I was home for lunch about 12:30.
Called Drew on the way home for lunch to tell him to come over later in the afternoon so I could get some generator wiring done first. The wiring worked out surprisingly well considering I had to pull additional wires through existing conduits. I was just wrapping that up when Drew arrived, kept himself amused inflating his tires and removing the tail lights while I finished my connections and tested them. The generator works as it should, and the shop transfers properly as well. Didn’t get to the house transfer switch yet.
At any rate, Drew has his new tail lights installed, he learned about solder sleeves and hopefully figured out why his tire was loosing air.
After he left, I went back to the generator project, studied the drawings for the Onan switch and came up with a plan that will be executed today.
It was refreshing to see that the inside of the switch matched the drawings, and all terminal blocks and wires were clearly labeled.
So after my bowl of Special K this morning I will start making up the relay harness that I need to add to make it all work. Once that is all done and installed, I really need to go around and police up the tools and supplies that I have scattered around while jumping from task to task. I’ve made a half hearted effort after completing each phase, but the bench is a disaster, as is most of the other horizontal surfaces in the shop.
It is a recurring situation that never seems to end. But I really need to gather up all the tools and put them where they belong, so I don’t walk around in circles looking for things.
Hopefully the rain holds off long enough to get at least the open areas mowed with the Progressive mower. Then I might put my feet up early, but that usually doesn’t happen.
/ Good morning!!!! #175,806
PJ, nice chain hoist! that sure looks handy and easy to use
don't forget your jackstands.
will be interesting to see if tpms system on rv shows full air pressure this morning on the suspect tire.
Pretty sure it will, think the valve extension was inadvertently loosened a few days earlier.
I tightened it all pretty well yesterday.
/ Good morning!!!! #175,807
The lithium polymer batteries we use in RC planes are charged in a fireproof bag and not left alone wile charging. We have fireproof bags in the airplanes for lithium battery fires in portable electronic devices, as a lithium battery fire is pretty tenacious.
Lithium batteries have incredible power density, but are not without their issues. There are also various chemistries used, some are more stable than others. So fires, while rare, do happen, and there are usually warnings and disclaimers on the devices and batteries.
/ Good morning!!!! #175,808
I wait for the trim mower battery to cool a little then put it on charge
sitting on concrete floor. You have to take it out of mower to charge, and when done,
I put battery back on top of mower, not inside.
has anyone heard of an EGO battery fire? I haven't.
I have a lesser brand name but you know the mower maker doesn't build the battery.
It's who they buy from.
I've never worried about my Makita batteries.
I do try to remember to turn the charger totally off when done, so it doesn't sit on idle.
all my chargers plug into a heavy duty surge strip and I turn it all on and off from there.
in the earlier days of firefighting the first toxic metal we dealt with was magnesium.
Those VW's had it in their blocks I think and when their crappy fabric fuel lines let loose,
it ignited the magnesium. We learned to carry bags of sand to smother the fire while also cooling it below
ignition point. And boy did that smoke smell horrible, before we put scba on for car fires.
/ Good morning!!!! #175,810
Do they still have the school bus demolition derby there? I haven’t been there in years, but that was memorable.
Good Morning Guys,
Lou, thanks for the update on Washington County !
50’s to start going to 73 or so ! Yesterdays big project was washing and waxing my 2017 F150 ! My right arm is a bit sore today, to much wax on wax off circular motions ! 😂 It’s supposed to be a once a year wax, which is a lot of baloney IMO ! But it does a nice job! It’s in an orange bottle, I think it’s NuWax or something like that !
I checked my camera, and it looks like I got my DW material delivered !
All have a blessed and safe day ! 🙏
/ Good morning!!!! #175,811
forgot to mention that I made a tray for the Makita yesterday to carry in the load bed of the RTV. It always slides around when driving and tips over so now it should be pretty stable
/ Good morning!!!! #175,812
70° same as it was at 1:30 am.
Weather underground struck out again. Called for rain last evening from 4-7pm, radar showed it coming and not a stop. Then it showed rain from 4 am till noon, not a drop and just high clouds this morning.
Paving guys working again. We didn’t get up early to walk because of the rain forecast.
PJ, been thinking of getting one of those hoists myself.
Drew, sorry about BIL
Wife just picked few more green beans.
/ Good morning!!!! #175,814
nice job Frits.
Scootr, they usually don't give us an option on chemistry. I do think there will be a new
certification standard for these batteries. Those fireproof bags Popgadget mentioned sound interesting, but if they are for a plane,
probably automatically cost ten times more
I used an AGM battery for sump pump. Would have preferred the LIPO4 but not sure oem built in battery charging system
would handle that.
dramatic use of new batteries in rv's now. Almost always a Battleborn or other maker LifePo4 option.
/ Good morning!!!! #175,816
Good Morning!!!! 72F @ 6:00AM. Plentiful sunshine. High 98F. Winds SSW at 5 to 10 mph.
Got back to Yankee Hill last night at about 6:30 after twelve hours on the road. Made a stop in Pollak Pines to pick up a new-to-me box trailer, and skirting traffic on the back roads really slowed things down. Good deal on the trailer, even though it needs new tires. The rest is all there, appears to work, and is in good shape. 7'x14', 7,000 lbs GVAW.
I feel your pain, literally, Kyle. Most of my finger joints have a little author-i-tis, and some get stuck once in a while, requiring a little help to get going again. Our reward for living this long I suppose...
Gosh, Buppies, what next? Fingers crossed for a good outcome.
"As for lithium-ion batteries, Chief Martinez says it is important to be extra cautious. He warns those who have them to not leave them constantly plugged in once fully charged. He adds do not keep them outside in a hot environment, but in a climate-controlled environment like inside. Also, inspect the batteries regularly."
Some good advice there, but don't think I'll be storing my Makita batteries in the house, no matter what the Chief sez.
Hope your plumbing job holds up better than the one here, David.
When I got home, I found no water pressure, and no water in the tanks. No sign of a leak, but the controller on the jet pump had shut itself down when it detected no water pressure on the in feed line. Got it going again and an elbow on the high pressure side started spraying through a crack. So this morning I've got some plumbing repairs to take care of. I'll be making a call to the contractor that did the installation to talk about the repair first, and then how or if they'll replace the 12,500 gallons of water that was lost. Records from the power system suggest the jet pump ran for about 18 hours before the water ran out. Until I can get it fixed I'll be flushing the toilet with a bucket and drinking bottled water. What fun!
While I was gone I found out that the Oregon dealer that sold me the van had been contacted by California DMV that they needed more paperwork before they could issue a CA title. And that they were sending back the paperwork submitted by the dealer. But the clerk at the dealer hadn't received it, so they asked me if I had it. It was in the stack of mail I got while I was gone, so instead of keeping the dealer in the loop, I'm just going to ask them to send the paperwork I sent them last week back to me. That way I can take the whole pile into a DMV office and work it first hand. It'll also get the bungling clerk out of the loop.
The cherry on the top was the jury summons I found in the mail pile...
And then there's the lady on FB Marketplace asking if the price is as stated in the swing set ad. The wording is "$1350 firm". Seems pretty clear to me...
Hang in there, gang, Friday's comin'!
/ Good morning!!!! #175,817
Good morning, low of 57°, only heading to 79° today. Heavy clouds this morning, left overs fro a brief shower last night. The rain gauge is "damp", but no real measurement ..... maybe that will change today....
I did get all the remaining gravel spread. I saved 'just enough' to cover what needed to be done. Could have used a couple buckets more. Next time......
Didn't get to the landscaping fabric and mulch yet. Didn't take any more pics yet....
Everyone have a great day!
/ Good morning!!!! #175,818
there are a lot of these battery bags out there, seem pretty cheesy to hold back that kind of heat if true thermal runaway
For sure. Those bags seem to be made out of plastic. Some have a layer of fiberglass, but none guaranteed more than 2200F coverage. I did notice one would refund or replace the bag if it failed. Great, what if it didn't save my barn or house? :rolleyes:
/ Good morning!!!! #175,820
Good morning , going up to 74 and cloudy, rain later.
Got 1 sheet rock panel up since work ran late and early yesterday.
Going through hell at work right now.
Sad about Bill, don't think I ever met him though Drew.
Got the M18 hammer drill yesterday, it's going back today as the clutch isn't working.
This is a certified, refurbished, that was done by someone who obviously has no idea how a hammer/drill/driver works.
Be well,
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
UNUSED SDLANCH 20'X20' HIGH END CARPORT (A60432)
UNUSED SDLANCH...
