which grease for slow & fast bearings & bushings
   / which grease for slow & fast bearings & bushings #1
orangetree
Gold Member
central idaho
kioti ck2610
Small TLB here with a few implements that have bearings such as a pto snowblower, pto chipper. I've just used the same grease all around until now - but it's been nagging me and I doubt my lithium/moly grease correct for the "fast" or "spinning" interfaces.
For the loader, BH, grapple, etc - the lithium-complex moly fortified grease does seem ideal. Note, I was jumping around brands as I could pick it up on the drive up, such as Valvoline Moly-Fortified Gray/Lithium Full Synthetic. I've realized this is stupid and have 'standardized' on, and now stock, John Deere HD Moly Grease Case TY6333 (picked the Deere because it seems the most consistently widely available online & in my area). I believe this (the Deere 3% moly lithium-complex grease) is the "optimal" choice here for these (A) low-speed/temp (B) high-pressure and (C) sliding surfaces.
On the bearings, though, hope I haven't damaged them, or caused myself a bunch of work to strip & re-pack :(. Using these two as an example:
  • snowblower 1st stage shaft bearings, chipper feed bearings: it's a bearing (eg not a sliding interface where Moly excels). But it's relatively low RPM so practical difference is probably really low(?).
  • snowblower 2nd stage is to be 500 or 1000rpm (eg roughly car wheel bearing speed), and are bearings not sliding surfaces
  • pto shaft u-joints: bushings not bearings (moly is good for sliding) - but relatively fast. Potentially too hot for lithium/moly to be ideal?
SO that's four types of interfaces. What's the "optimal" grease for each? If I want to do it right, I don't mind keeping multiple grease guns. I'd prefer to have everything last as long as possible, and/or require minimal disassembly/cleaning/service (beyond daily greasing).
  1. Slow + Sliding (bushings in loader pins, etc)
  2. Fast + Sliding (engine-speed U-joint bushings such as PTO)
  3. Slow + rotating (slow (10's or RPM) ball/roller bearings - geared down shafts)
  4. Fast + rotating (engine-speed ball/roller bearings)
Tentatively I believe I should be using lithium/moly for #1, and polyurea for #2 & #4?
Thanks!
based on Project Farm's results, I suppose I should also consider a high-quality lithium-complex NON-moly grease for the high-speed applications (such as Lucas Red "N" Tacky he reviewed very positively)
Side benefit is that I couldn't mess anything up if I used the wrong gun (since both are lithium-complex)
   / which grease for slow & fast bearings & bushings #3
My understanding is moly greases are great for sliding surfaces but you do not want to use moly grease on a roller or ball bearing - it's TOO slick and the bearing can slide on the surface instead of rotating.
   / which grease for slow & fast bearings & bushings #4
Thanks!
In my mind lithium or calcium grease are adequate for all four of your needs. I have used lithium for all of those uses without issues.
I am currently switching to an anhydrous calcium grease for all of those uses and I expect it will perform fine. I purchased it in bulk to try to save a few bucks.
I think greasing interval can be as important as anything. If the greased assembly rotates rapidly and slings the grease out, grease more frequently. If the slow moving assembly got rained on, grease it to force the moisture out.
My criteria for grease is that it be easily available, inexpensive, water resistant, and adherent. Polyurea can be relatively expensive and sometimes short in supply, which is partly why I stick to lithium and calcium greases.
   / which grease for slow & fast bearings & bushings #5
good grease is never cheap is my only comment other than I use Lubrication Engineers teflon fortified grease for everything and I buy it in 150 pound open head drums that fit my ARO air greaser and I fill my lever guns from it as well and in every implement tool box is one and they are all refilled regularly. The kicker is a 150 pound drum is 1500 bucks plus delivery. Been using it for years, no issue at all. I go through about 150 pounds every 2 seasons.
   / which grease for slow & fast bearings & bushings #6
All the universal joints I've worked on had needle bearings, not bushings, so should have non-moly.
Ok, looks like no feedback against non-moly lithium (Red-N-Tacky), so put in an order for that. Should have about a years supply now :)
To tl;dr for any future readers, this is what I'm using going forward:
  • 3% moly lithium-complex (Deere TY6333) for:
    • Slow + Sliding (bushings in loader pins, etc)
  • non-moly lithium-complex (Lucas Red "N" Tacky) for
    1. Fast + Sliding (engine-speed U-joint bushings such as PTO)
      1. note, in case these are bearings as @BigGG mentions, this is still good; you just don't want Moly on parts that aren't meant to slide). Either way, "fast" and "high pressure" are sort of inversely correlated, so Moly wouldn't be critical here either way
    2. Slow + rotating (slow (10's or RPM) ball/roller bearings - geared down shafts)
    3. Fast + rotating (engine-speed ball/roller bearings)
Red-N-Tacky has a drop point at >500 deg-F ... if my equipment gets anywhere near that I am doing something drastically wrong :)
   / which grease for slow & fast bearings & bushings #8
I used to use Red & Tacky but got tired of it separating out in my gun in the heat of summer & dripping all over everything. Switched to Lucas Xtra HD green polyurea and JD SD polyurea and have never looked back. Both mix well with lithium based greases and they don’t separate out. This has been my one grease for everything for several years and has served me well in my driveshafts, FEL, BH, etc.
   / which grease for slow & fast bearings & bushings #9
Thanks!
I can’t recommend because it would be a guess. If you utube please watch the AMSOIL grease video. Andy there is a guy that does the comparison with a lot of other high class brands. I think you would really enjoy this
   / which grease for slow & fast bearings & bushings #10
   / which grease for slow & fast bearings & bushings #11
I have been using Lucas or John Deere polyurea grease for about as long as I can remember.
I do a lot of mowing and spraying each year, and so far, no problems with some old but regularly serviced equipment
   / which grease for slow & fast bearings & bushings #12
I use Lucas Marine in everything for over a decade. I like the extra moisture protection the marine grease gives. On my 5 trailers never had a bearing issue. When I replaced my hubs on the boat with Vortex (6 year 100K warranty) they specified Lucas Marine. Figured it must be good with that warranty.
   / which grease for slow & fast bearings & bushings #13
I use Lucas Marine in everything for over a decade. I like the extra moisure protection the marine grease gives. On my 5 trailers never had a bearing issue. When I replaced my hubs on the boat with Vortex (6 year 100K warranty) they specified Lucas Marine. Figured it must be good with that warranty.
Thanks that is an awsome suggestion. I believe in quality grease. I made a mistake that will take me a while to use up. I got a case of 10 tubes from AMSOIL. I think just the moly kind per his unprofessional recommendation. Live and learn sir is my motto. Again thanks. I have quit AMSOIL all together
   / which grease for slow & fast bearings & bushings #14
I agree with you on Andy. But I do business with AMSOIL and the people on the phones sometimes don’t have an idea their product. It’s just to sell
   / which grease for slow & fast bearings & bushings #15
I've heard that too, but don't know if there is anything to it or just something made up because it sounded good. i.e. mechanical folklore.
I use JD polyurea grease on everything except a few bushings that are heavily loaded and move too slowly to develop an protective oil wedge.
BH swing and the loader bucket pivots are the ones which get 3% moly.
rScotty
   / which grease for slow & fast bearings & bushings #16
I use Royal Purple and have for 20 years. We used it on all of our motors at the power plant. If it will keep motor bearings working there it is good for me. You can use 1/2 as much at 1/2 the intervals. I used to get the grease and motor oil free from the rep that called on us. I was using it before you could ever buy it across the counter.
   / which grease for slow & fast bearings & bushings #17
I used to use two greases. Moly for low speed high pressure. Like loader/hoe pins and bushings, ball joints, tie rods, etc. And a synthetic lithium like mobile SHC32 or SHC460 for high speed bearings. Like u-joints and mower deck spindles.
But now.....I think a urea based grease is a good replacement for BOTH. They have good EP properties like moly.....but also equally good specs for bearings like a synthetic lithium base.
Look for a urea based grease and use it for everything
   / which grease for slow & fast bearings & bushings #18
It’s always interesting to see what other folks use. I use Nyco GN06 on my rotary cutter driveshaft profile and ThixOgrease 2 for everything else.
   / which grease for slow & fast bearings & bushings #19
Hi,
Texas Refinery 880 Crown and Chassis in everything. You can order online. The only grease that stopped constant bearing failures in flail mower roller assemblies in Alamo when I worked for the Turnpike mowing 216 miles of highway in mud and water constantly.
Brian
   / which grease for slow & fast bearings & bushings #20
I don’t follow why you think you got an inferior grease! Yet somehow you think that a marine grease is better for your application. I may have missed what it is that you’re greasing…but I didn’t think you mentioned any marine equipment. If you’re running a moly grease in a piece of agriculture equipment or similar, I would think that you’re using the appropriate grease. Anyhow let us know how many bearings/bushings you had to replace during the use of the 10 tubes of Amsoil grease 😉
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
