What have you done to your Branson today?
   / What have you done to your Branson today? #1,401
You're just spoiled by the cab. That's all. 🤣
Mine is currently sitting idle all ready to go in case of a fire. Got an IBC on the dump trailer, got a small gas water pump and a couple feet of hose. Hopefully I don't have to use it for that duty though.
   / What have you done to your Branson today? #1,402
I hope you don’t either. My son lives in Maui and my daughter-in-law’s office she works in burnt down in the fires they have going on right now. They are safe so far where they live though.
   / What have you done to your Branson today? #1,403
I've been following on the news. That was terrible what they went through.
I removed the inspection plate and had a look around. Best I can tell it is the rear main seal. I also removed the starter and went between the flywheel and back of the motor with my camera but could not tell much as I was seeing more of the top side of the crankshaft. But I did go to the bottom of the bell housing and see some evidence of the leak.
Called dealer and they said is should be covered
Called dealer and they said is should be covered under the power train warranty. Hope they are correct. I will take it to them next Saturday.
Pic of the plate after I loosened the bolts.
Pic of oil on top of plate.
Pic of the inside.
Pic of the bottom of the throw out bearing.
Pic of the bottom of the bell housing behind the flywheel.
Pic of the inside.
Pic of the bottom of the bell housing behind the It's obvious by the dust accumulation that you have a leak.
It's obvious by the accumulated dust that you have a leak.
Details, details..., did you drain it before removing the plate? That small omission could change this whole story.
   / What have you done to your Branson today? #1,405
There is nothing to drain to remove the plate. That is the bell housing between the engine and transmission. There should not be any fluid in there.
The dust is from doing the road work with my brother at his deer lease. It is terribly dry here and that was very dusty job. My brother has an open station JD and he had more dust than that all over him. :ROFLMAO:
I don't know what I was thinking, lol. Correct, oil is bad in the clutch assembly. Take it in as soon as you can, because you want to avoid any games that might happen due to the delayed time.
   / What have you done to your Branson today? #1,407
Branson? Point and laugh at them. :LOL:
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2009 BMW X3 Sport AWD SUV (A56859)
2009 BMW X3 Sport...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
Hose Reel (A55758)
Hose Reel (A55758)
