tacticalturnip
Super Member
That is really cool to see.
Your camper also sets higher, which makes a difference. Nice looking trucks.That’s why I got a Cub instead of a Super A. I hate trailers and my parents farm is 20 miles away from our’s. The Cub only goes about 11 mph at wide open throttle in 3rd gear. It would take me most of a day to drive it over there and back, but I can get it over there in just over 20 minutes, in the bed of the truck.
They have a perfect spot to unload over there. I just back up to the raised sand-filter septic system in their front yard. I was getting some looks while loading up from the folks shopping for chainsaws and lawn-mowers at the dealer’s shop across the street.
The Cub, even with loaded rear tires, must be considerably lighter than my 8 ft camper, because the truck handles better in the turns with it on back.
If those 6.0 liter Chevy V8’s really are good for over 300,000 miles, then both of those trucks ought to last considerably longer than I will. I’ll be 98 in 40 years. Both of those 00’s have about 80k miles on them now.Your camper also sets higher, which makes a difference. Nice looking trucks.
That is very likely!No rust problems at all with the rust-proofed “Florida” 2wd but I did have to replace the air conditioner manifold on it last year. I suppose my uncle must have used the heck out of that down in Florida for a lot of years.
OP Congrats on the New Super Duty.
is it still in warranty with those miles, or if not possible to buy an extended warranty that covers the CP4?
If so it might be worth consideration for some extra protection long term.
Good looking rig!
A bunch of years ago I had an '08 F-250, I also did the research between it and the F-350. At the time the only difference the parts guy and I found was that the F-250 had a 2" spacer above the rear axle and the F-350 had a 4" spacer in the same spot.
Most likely the dealer filled the tires to max. Try running them at pressures correct for the actual axle weights, according to a load chart, and the ride quality should improve a lot.First trip home I realized just how stiff the suspension is. I knew a HD truck would ride stiff and I am fine with it. I’m just surprised at HOW stiff it is.
Beautiful truck! Love that color.I did decide to go ahead and pull the trigger, signed the papers last night. It’s a 2019 F-250 Super Duty Supercrew 4x4.
First trip home I realized just how stiff the suspension is. I knew a HD truck would ride stiff and I am fine with it. I’m just surprised at HOW stiff it is. My Dad has a 2017 Silverado 3500 diesel and it rides the same or slightly better than this Super Duty F-250. Granted, the previous owner did put airbags on the rear of this truck, and I haven’t had time to investigate yet to see if they are hooked up to an automatic load leveling system or if they are manual inflate/deflate. The power from this diesel engine is ridiculous. It’s a 7,800 lb. truck and it’ll eat the tires for lunch when a light turns green if I’m not careful.
Payload rating on the door placard is 2,350ish which is a 44% increase over the Ram 1500 I traded in. Trailer towing capacity on this truck is 14,700 which is a 77% increase over the Ram 1500.
Heck I drive my 5500 and the rear spring packs are huge, but I’m used to the ride.Initial impressions after 28 years of driving ½ ton trucks from all the brands:
This thing sits up high. Feels like a ½ ton truck with a 6” lift kit on it. My 5’3” wife ain’t gonna’ be happy.
This truck rides like a tobacco wagon. My father has a ’17 Sierra 3500 HD that rides better than this ’19 F-250. My truck has the standard suspension. Does not have heavy service package, etc. I can’t imagine driving one of these trucks with that up-rate suspension. That would be brutal.
The steering on this truck is very slow. Seems like the ratio in the steering is a very low ratio. Takes a lot of turn on the wheel to get response from the tires. This is probably the biggest thing I’m having to adjust to. It heavily affects driving on our one-lane rural roads.
The driver seat is just terrible. The lower cushion is soft and comfy, but the back of the seat is curved far too aggressively. It pushes really hard right in the middle of my back. Adjusting the lower lumbar helps just a tad, but overall the contour of the seat is a joke. The human spine curves in low, then curves out in the middle, then back in toward the neck. This seat is contoured exactly the opposite.
More positive notes: The Power Stroke engine is amazing. Good power, showing 16 MPG so far. All fluids are easy to get to. Air filter box doesn’t require tools. And I love that the 6R140 has a real dipstick and a drain on the trans pan. That’ll make maintenance at home easy as pie.
Best part about the diesel world is all the friends you make along the way.Welcome to the diesel world. You’ll likely never go back to gas. After 30 years with diesel trucks, I never will.
I dunno. After three or four diesels, my girlfriend got rid of her 2500 Cummins and bought a 3500 longbed with the 6.4. And she really likes it.Welcome to the diesel world. You’ll likely never go back to gas.
