House Build 2023
/ House Build 2023 #61
Some random thoughts from my house build....
Look at getting a radiant barrier on your roof decking, which should help keep attic temps down. Agree with folks on air sealing -- recommend reading up on greenbuildingadvisor or energyvanguard blogs.
I've read many horror stories on spray foam....it works fine most of the time, but when it goes wrong it goes really wrong and is a pain to remove. I tried to avoid it where I could, and just using it for crawlspace walls and rim joists. In my experience, builders think spray foam has some kind of "magic", but really the trick is just air sealing, which you can get by taping your sheathing seams (using zip or just OSB/plywood) or using some kind of vapor-permeable membrane.
re: rigid vs flex duct -- My insulation contractor did a great job with the batt insulation in my vaulted bedroom ceiling, but I'm pretty sure they crushed the flex duct for one of the supply vents in there. The upside to flex though is fewer seams/connection points.
On HVAC, the upside of the variable speed systems is they can modulate to lower output, so run longer/more to do a better job of dehumidification. Contractors often oversize systems, and if it's single speed then you'll have the system run full-out for very short cycles, doing a poor job of getting even temp throughout the house and removing humidity from the air. Variable speed systems are better in that regard, especially if you can't trust your contractor to not oversize your system (the contractor our builder commonly uses wanted to oversize our system by more than double).
Did the contractor do a Manual J to determine the load, and from there a manual S to size the system? I'd recommend asking to see it - their response will tell you a lot, and you can verify their inputs are correct (design temps, # of occupants, load from appliances, insulation values, etc). Again, we had a bad experience with our builder's contractor but luckily had hired a consultant to do the calcs for us so we were informed consumers.
/ House Build 2023 #62
One thing I did prior to blowing insulation to R49 in the attic was to build a catwalk in the V of the trusses. No I can't reach all areas, but I can go the whole length of the attic. Also put LED lights with a switch seen in the access closet ceiling. Also no storage up there. Jon
/ House Build 2023 #63
I would do metal ducts any day over flex. Better air flow, flex restricts too much. My 2 cents.
/ House Build 2023
Got the lumber/roof materials package quotes today. The materials are similar except for a couple areas. Let me know if there is a preference.
Both have radiant barrier OSB for the roof. one is 7/16 one is 15/32. not sure if that even makes a difference. About $4.00 each more for the 7/16 but it's the overall higher quote also.
The bigger difference is ZIP panels on one quote vs standard OSB and housewrap on the other quote.
GAF vs Tamco shingles. Tamko are cheaper by about $10/sq
/ House Build 2023 #65
I imagine the thicker decking might be good for future solar, if that's something you've considered?
/ House Build 2023
The last time I checked the best case scenario was a 20+ year ROI for the solar if there were no maintenance issues. That is not something I want to consider. Even if it was 15 years that would be a no-go. Our electrical grid is not prone to issues aside from short interruptions from weather or the odd car taking out a pole. I am installing a small manual transfer switch for a generator big enough to keep a few essentials going.
/ House Build 2023 #67
Fair enough - not trying to convince you, just throwing that out there in case you hadn't considered it
/ House Build 2023 #68
Walking on 7/16" may fel spongy compared to the 15/32". Just my thoughts. Jon
/ House Build 2023 #69
You guys are behind the times on the electricity. New code required a disconnect on the exterior of the house that the FD throws before fighting the fire. It is separate from an old meter base and panel. It is a single full disconnect with one pull simular to an AC disconnect. We were able to put the meter on my pole 400 ft away and bury the line. Best thing....
/ House Build 2023 #70
Oh, and our first home we built had a set of French doors that worked perfectly for 13 years and and most probably since we sold. As solid and as insulted with zero air leaks. Our main solid wood had leaks, not the French doors.
/ House Build 2023 #71
ZIP Panels are a much higher quality OSB. When cutting them, they are more solid and they don't peal, like regular OSB does. Same with SMART Panels. When left exposed for awhile, I think ZIP Panels are worth the money, but if you are going to be moving along in a timely manner, then house wrap is a better value. The other advantage to ZIP Panels is the air seal is usually better because everything is taped with ZIP Tape. That tape is the best stuff ever invented, I use it for everything!!!! I couldn't get through life without a roll of it in my truck. The living area in my house is all ZIP, but my attached garage is done with house wrap.
ZIP System has a 5/8 panel that's reddish in color for roofs. Its probably the very best option out there, but also very price. I've never used it because of the cost. My house has metal roofing on purlins, so there isn't any decking of any kind on my roof. But just about every house out there is decked with regular 7/16's OSB or half inch plywood on trusses or rafters 24 inches on center. OSB holds nails better they plywood, but for some reason, there are people out there that have something against OSB, and they use plywood instead. I hate plywood for roofs because it has so many voids in it, and the third layer has a habit of blowing out when nailed, which only leaves two layers of wood to hold the nails in the shingle sin place.
/ House Build 2023
A little update. I don't think I have shared much progress yet. Here is a "start to finish" on the driveway.
I cut down the top soil with the dozer and hauled it to the back for use later. Then I made 2 lifts of shale. It was saved from the pond project last year. I'll wait as long as I can before I have gravel hauled in to cap it. I figure I'll have to grade it a few times from all the heavy concrete trucks and other deliveries.
/ House Build 2023
Also it turns out it really takes longer than you would think to build a 450' driveway and house pad by yourself. Lots of climbing in and out of equipment. I think I hauled off easy 40+ loads of top soil and hauled back an easy 60+ loads of shale. I had help for the middle of 1 day. Other than that it was just me. In the track hoe, out of the track hoe and into the dump truck, back out of the truck and into the track hoe, then truck, then dozer, then truck, then back to hoe... and so it went for 2 full days and 2 evenings after work.
Worked on equipment all day Thursday. Dirt work from can-see to can't-see Friday and Saturday. Rained out Sunday. After work at my real job to can't-see Monday and Tuesday and finished Tuesday night. Tuesday felt like the longest day, I moved and graded 17 truck loads after working all day at my day job.
Builder said I would have had to pay around $10k if I had hired out the driveway build. I burned about $400 in diesel, so I think I ended up on the winning side.
/ House Build 2023
Here's a little view of the water and electric service. I already had a big track hoe at the house so I decided to use it to trench for the utilities instead of renting something smaller. Turns out a 42" bucket makes a BIG trench. I'll rent a trencher if I ever have to do this again. Electric required 36" depth and water wanted 3 feet of separation from the power. The 42" bucket made the spacing easy. I just kicked the water to one side and the electric to the other. The bucket vertical in the hole was around that same 42" deep, so that's what I used as a gauge. With the small fluctuation in depth, the top of the conduit never got less than 36" deep. I used 20' sticks of bell-end schedule 40 - 1.25" for my water. Electric is 2", also bell end, sch 40 undergound, sch 80 sweeps and a small stub of sch 80 to get it above grade. I bought 420' of water pipe and 460' of conduit and used all but 1 stick of each.
20230627_203740.jpg20230630_133433.jpg20230630_133556.jpg20230630_133605.jpg20230701_195605.jpg
/ House Build 2023 #75
Go with zip sheathing for walls and roof if you still have the choice to make! Far superior durability, long-term rot resistance, air sealing, etc.
/ House Build 2023
I'm going zip on the walls. it looks like you either get zip for waterproofing on the roof panels or thermal barrier, not both. I'm opting for the thermal barrier.
/ House Build 2023 #77
Did you pass inspection with both the water and electric in the same trench? Here, they have to be in separate tranches.
/ House Build 2023 #78
Not sure exactly what you mean by thermal barrier. But my roof has the 5/8" zip, fully taped of course, plus 1" polyiso insulation, also fully seam taped, then another 3/8" OSB layer atop that for better support and fastening of the standing-seam roofing. (it was a pricey roof assembly, no doubt).
In retrospect we probably didn't need the zip sheathing on the roof, since it has a fully taped layer of foil-back polyiso on top of it, BUT, certainly doesn't hurt either.
/ House Build 2023
The water department only inspects the hookup at the meter and electric says they only need a foot of separation. I did send pics to the Entergy engineer assigned to my project and the inspector for the water department before I covered the trench and they both said they were good with it.
/ House Build 2023
Thermal barrier is OSB with almost an aluminum foil looking backer that is supposed to reflect thermal heat radiation from the roof. Everyone I've talked to said it makes a big difference. I'm spending a small mint on this thing already. I can't go Cadillac on everything. I am going with high quality shingles and underlayment.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2007 Econoline Trailers Trailer (A62613)
2007 Econoline...
John Deere 33 Manure Spreader (A66408)
John Deere 33...
