3 point rising up
   / 3 point rising up #1
Shepstone
Member
CG1710
High guys my 2018 Massey gc 1710 has an issue where the 3 point won’t stay down. I initially thought it was because in the winter when using a scraper blade it was to light and the snow would push the blade up, but I’ve now got a tiller that weighs almost 600 lbs and it’s doing the same thing. I have to constantly hold down the 3 point lever in the down position or the tiller will raise up. It’s getting frustrating, is there an adjustment that I’m missing? Thanks all.
   / 3 point rising up #2
Not enough info here to know what exactly is causing your issue. One thing is certain: the 3pt does not rise without hydraulic pressure via a valve which SHOULD be controlled by that position lever. It would seem to me you have some kind of failure of the valve being controlled by that lever. Sorry cannot help. Do not own a GC. Surely others will come on here and give you a helpful answer.
   / 3 point rising up
Thanks for the response, Hmm, ok so when I use the tiller I lower it down to ground and start moving forward, then it will on its own raise up a few inches, so I push the lever down again, if it gets raised up from going over a hump or pushed up by hard dirt , it won’t go back down, and will stay raised, so I’m either having to keep an eye on it all the time to make sure its down or drive with one hand holding the lever down, neither of which is a comfortable situation.
   / 3 point rising up #4
The GC's do not have a Draft Control mechanism do they? I thought not, which is why I did not bring it up earlier. If your tractor had Draft Control that might be causing the symptoms. If there is draft control make sure it is shut off.
   / 3 point rising up #5
No draft control on a CG.
Are you sure the 3PT is moving up?
I deal with this all the time with my snow blower on my humpty bumpty driveway/yard. It only goes down as far as it can. Then if the front wheels hit a dip and the back wheels hit a bump it brings the implement goes up and needs to be lowered some more. There is no "float" so I have to hold the lever down until I've gone past the first big dip.
Might not be your problem, it could actually be raising, maybe you have a leaking valve or something allowing fluid through.
   / 3 point rising up
You maybe right, but I can lower the implement all the way over an edge where it’s hanging in the air before moving forward to engage the ground so I know it’s fully lowered. But as soon as it engages it has to be lowered again, it maybe designed that way. but if it is it would be annoying for anyone with a 3 point mower deck going over bumpy terrain. I will try adjusting the rate of drop knob and see if that makes a difference. i would think there is some kind of float that keeps it down but there’s no indication on the lift and lower lever.
   / 3 point rising up #7
There is no float, and it is not designed to go back up. Once lowered to a specific point it should continue to return to the point. When the ground pushes it up it only pushes on the lower arms. This can be tested with your implement off. If you lower the 3PT all the way you can manually lift the arms about 1 foot and then they will drop down to the same position. I don't know what would happen if the ground pushed it up past that 1 foot of play. Are you tilling over hills that are more than 1 foot high?
   / 3 point rising up
The lower arms do float but when it’s hooked up to the hitch it’s all connected to the hydraulic raising arms that raise and lower it meaning everything gets pushed up. Maybe I’m hooking it up wrong? Any way for the time being I’ve installed and L bracket that holds up the lever spring that makes the lever return to middle position, it only affects the lowering not the raising, so now the lever stays down when lowered. So now it “floats”.
   / 3 point rising up #9
That reminds me to mention to the OP: All modern 3pt systems are held or moved downward only by gravity and can apply only upward force. He probably knows that ?
   / 3 point rising up
Ya it’s gravity down, just seems odd that a 591lb implement won’t stay down by gravity, it’s good now that I modified the spring on the lever. I still think it’s supposed to stay down by itself without having to hold the lever down all the time.
   / 3 point rising up #11
So just to clarify, if you just park the tractor, lower the 3pt, you could observe it raising up? Or are you saying when you manually raise it (like going over a bump bumps it up), it doesn't lower back down to original lowered position?
  • Good Post
Reactions: JWR
   / 3 point rising up
Second one, going over a bump or when first moving ahead.
   / 3 point rising up #13
Well, any implement (and certainly a 591 lb one) will lower the 3pt hitch to the level allowed by the position control lever. I do not fully understand what all you did nor the spring business.
To my knowledge position control levers are all designed to push forward for lowering AND when released go back in a spring loaded manner to a neutral position (not calling for any lifting or further lowering.)
If you have to hold the lever down something is wrong. When you hold the lever forward, calling for downward motion of the 3pt, under force of gravity, the 3pt should reach its lowermost limit and quit. Beyond that the lever should (when released) go back to neutral status. Nothing should be lifting the 3pt after that except for
A) you pulling the lever back to the rear for lifting or
B) some external force pushing the implement upward.
If the undulations of the ground (or any other external force) pushes the 3pt and implement upward when fully down it will return to the fully down position once it ha clearance to do so unless some external force pushes it up. ANY other behavior and there is something wrong. The end.
   / 3 point rising up
You’re right the implement should stay down once the lever lowers it, but as it goes over a bump which pushes it up it doesn’t return to its lower position, all the spring does is pull the hand lever back to the centre. Without the spring applying force to re-centre the lever, the lever will stay down keeping the implement down.
   / 3 point rising up #15
You could park it and while its running use a jack to lift the tiller off the ground and then see if it goes back down when you lower the jack. It should if everything is working right.
   / 3 point rising up
Is anyone else having the same issue where the implement stays up after going over a bump?
   / 3 point rising up #17
No, the lever staying down does NOT keep the implement down. The 3pt lift having been lowered before that will leave the implement down, not because the lever is still forward/down. Your spring might be moving the lever past neutral and into a lifting mode but presumably not since you installed the spring after the whole issue arose...
I do not believe we can resolve this in the feeble mechanism of the English language. Good luck to you.
   / 3 point rising up #18
My flail takes a while to go back down so I push the lever down.
I have a lot of dips where I use the flail on the trails and between trees.
   / 3 point rising up
Thank you everyone for your input, I apologize for my clumsy explanations it probably didn’t help matters. For now I have a work around with the L bracket. Thanks again.
Martin.
   / 3 point rising up #20
Really no need to apologize for anything. If you figure it out I'm still curious what can cause it just in case I ever have the same problem.
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
