Seized engine
/ Seized engine #1
Spikes
Rogers, Ar.
Kubota L3450
Hi everyone,
I haven't been on here in a while. Had some (10) surgeries that left me living in a nursing home and having to learn to walk again, but I'm back now and doing fine.
While I was down, my Kubota L3450 sat out in the weather for 3 years, and apparently got water down the exhaust (stock with the foward-facing 90° bend at the top). Strange thing is I was able to start it two years ago just before Winter and it started fine with a new battery, I was able to drive it to the carport where it lives. There was no indication that anything was wrong at that time. Went out to start it at the end of last year and just got a click and a really high current draw. I replaced the starter thinking it was that but still does the same thing. I'm unable to turn the engine with a breaker bar, but I haven't tried too hard as I don't want to break the front pulley bolt off. I poured a bottle of seafoam down the exhaust a week or so ago just to help loosen things up if that's the issue. Some of it came out the bottom of the manifold so there must be a leak in there. Oil level is fine and was fresh just before my health went down.
My question - Am I correct in thinking I can put the transmission in reverse 8th gear and pull on it a bit with my truck's winch? It's shuttle shift. It will have to be reverse because it's nosed into the carport. I can hook to the brush hog on the back.
I'm guessing I'll have to put new diesel in, the stuff that's in there is 5 or 6 years old now.
Thanks!
/ Seized engine #2
Oh dear ! The Seafoam is an extraneous topic. Most of it evaporated by now and you see it around the exhaust manifold because the valves were in unknown or partially open positions. Leaky exhaust manifolds are also the least of your problems and that exercise did not accomplish anything.
Eventually you need to get the fuel out, probably change the filters and all that but you have a more pressing issue.
I have not seen in your comments any reason to think the engine is actually siezed. Especially since it started and ran a couple years ago. No idea in the world why you replaced the starter. Knowing nothing about the surroundings where you keep the tractor or what other extenuating circumstances there are, I would think you need a helper while working with it. You should be able to put it out of gear pull it (with whatever you have) out onto level dry pavement and let one person ride it while the other pulls it slowly with the truck. Put it in the correct direction gear you are pulling it , hold the clutch in until you are moving good and pop the clutch. That should free the engine rotation. No winches involved.
Do not know what circumstances were when you used a breaker bar to try to turn the engine. Maybe it is siezed but we have no clues here as to why, if it is.
/ Seized engine #3
Absurd of me to join in since I know less than nothing... Is there any possibility that an internal coolant leak could hydro-lock a cylinder? Maybe pull the glow plugs and try that bar again? Leave them out when you do the brute force tow-to-free thing?
Just askin', not sayin'
Zoltan
/ Seized engine
I appreciate the reply. I used the seafoam because I wanted to get something around the valves incase water had gotten down in there. I'm not sure what that could hurt, so I'll leave that part alone in this reply. I replaced the starter because it wasn't able to turn the engine over and appeared to be locked up. It was a preliminary step in diagnosis - the old starter had given me problems in the past so the replacement was due anyway. If the engine wasn't seized, I don't see why the starter wouldn't be able to turn it. As far as helpers, I don't have one so it's the truck and I. I was hoping to move the tractor a little while it was in gear and see if that got the engine moving a little.
/ Seized engine
Good thoughts, and something I had considered. I think the engine would have turned a 'little' bit when I first tried to turn it, but even so, I checked the coolant level and it's full. I will be pulling the injectors if a gentle tug doesn't get me anywhere.
/ Seized engine #6
I'm with you, give it a gentle tug and see what happens.
/ Seized engine #7
Pull the glow plugs and pour transmission fluid in each cylinder. Do not try towing to start. Let the tractor set for a few days and then try rocking the engine backward and forwards. You should also remove the rocker cover and watch it as you are doing the rocking backwards and forwards. Watch the cam, rockers and push rods to see if they move freely you may also have frozen lifters.
After you get the engine where it will rotate freely leave the glow plugs out and spin the engine with the starter to blow the transmission fluid out of the cylinders. I have also seen the injectors have to be removed and oil poured in the cylinder through the injector holes.
A lot of the old tractors with the exhaust pointing straight up had this problem if a can was not placed over the exhaust stack when left setting outside.
/ Seized engine #9
I'm not sure which bothers me most,your tractor seized,your health problems or that noone will come over to help you. If the engine hasn't freed up I'm with Gator about removing glow plugs or injectors then pouring 6 oz penitrating oil in each if you can afford it,mixture 75% atf + 25% Acatone if on a budget. Stay after it with the bar until it can be turned at least one complete revolution then spin with starter to remove oil and make on hell of a mess on the ground. The problem with towing it is that rings can be broken when piston is forced to move. I had to rock 2 different engines on and off for weeks before they moved then spent another week rocking back and forth until the engine could be rotated through a complete revolution.
Win,lose or draw I wish you would just give us a shout,I'm worried that you've injured yourself or worse.
/ Seized engine
Hi jaxs,
I appreciate the reply. I haven't gotten back out there to do this yet, I am on the same page as far as pulling the injectors after reading some more on the subject. I certainly don't want to destroy the engine by being too aggressive.
The thing that's got me puzzled is that although the tractor did sit out in the weather for a long time, it started, and I was able to drive it before parking it where it lives now under the carport. There is no way water has gotten in the exhaust since I moved it, as it's well covered now. I recall now that I drove the tractor around until the engine was up to full temperature, as I didn't want to cause condensation to form in the crankcase and then park it.
I'll do some more diagnosing once I can get back out to the machine. I'll have the tools ready next time and be able to pull the injectors.
Appreciate you all taking the time to reply!
/ Seized engine #12
Stupid question, any chance it's in gear and the clutch is stuck?
Not at all stupid,slightly stuck piston or two combined with compression and turning mechanicals through clutch would be a heavy load to move by hand. Opening cylinders to relieve compression might be all it takes. I'd certainly use the delay for my advantage by keeping lubrication soaking in cylinders.
/ Seized engine #13
I was going to mention the clutch. if the clutch is seized you would be trying to turn the whole geartrain if it was in gear, unless in neutral then just the shaft.
/ Seized engine #14
If a straight drive tractor, put the transmission in neutral. If a Hydro put the selector lever in neutral. Then jack the rear wheels off the ground and try to rotate the engine. If the clutch is seized the rear wheels will turn.
  • Good Post
Reactions: JWR
/ Seized engine #15
On that series of Lxx50 models with vertical exhaust there's a 1/4" weep hole on the bottom of the exhaust elbow that's intended to be a drain for any rainwater that goes down the stack. Seafoam running out shows its working.
/ Seized engine #16
Is your battery 100%?
On my backhoe, I had a loose fanbelt. Tight enough to work, loose enough to not really charge....so the battery was slowly dying.
When I try to start it, it would click and start drawing amps but not turn engine over. Got the battery charged and now it's back to starting immediatly.
Of course, this has no bearing on being able (or not) to rotate engine by way of turning the crank by hand....
2005 Freightliner M2 106 Ambulance (A61573)
2005 Freightliner...
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
2006 KENWORTH W900 T/A DAYCAB ROAD TRACTOR (A64276)
2006 KENWORTH W900...
MAYTAG BRAVOS XL WASHING MACHINE (A64281)
MAYTAG BRAVOS XL...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
