Brush Hog mods
/ Brush Hog mods
Yeah, couldn't say for sure about the price, what I can say is most of the things I see like the Italian made 3 point hitch fertilize spreaders and finish mowers are very competitively priced and from what I have seen are of pretty good quality.
Please post some links to these mowers for sale in the USA
/ Brush Hog mods #62
I don't even know how to post a link, but if you will google Caroni finish mower or Caroni flail mower you will find them in the USA for sale, Agri-Supply being one place that I have seen them at when I went to one of their stores in person , as well as the 3 point hitch fertilizer spreaders I mentioned earlier.
/ Brush Hog mods
I tried. I only found blade mowers under that name.
/ Brush Hog mods #64
Yeah, I never said that they advertised chain mowers only that they imported a lot of Italian equipment into this country and probably with a request you should be able to get one if you really wanted one. So when you google you don't see the Caroni flail mowers? Only the finish mowers?
/ Brush Hog mods #65
I haven't seen any brush mowers in the USA like the ones ptsg posted in posts 4 and 5. Even the brush cutters for skid steers in the USA seem to mostly rely on swinging blade designs with only a very few using disc mulching head assemblies and none using chain as cutters from the factory that I know of.
Still, the idea of modifying a brush cutter blade to put a chain at the end is a bit terrifying to me both for the forces exerted on the chain and for how the chain is secured to the cutter blade, as modified.
/ Brush Hog mods #66
Things I'm still wanting to do to it. Add skid plates 2x2 angle to the skirts.
Add chain to the front opening. Can anybody recommend a size and spacing for the chain? Replace broken grease fittings and grease. After testing - if warranted... paint
PICS TOMORROW
it’s been 6+ days. What’s the holdup? ;)
/ Brush Hog mods
Lol. Life and work are getting in the way.
Also gathering materials to improve on the deck. Extending the front edge 4" so the blades don't stick out past the front of the deck anymore and adding a chain guard. I'd like to make this experimental mower conversion as safe as I can. Will post progress when it is made.
Went from making my own chain guard to buying a manufactured 5 ft curtain. Meanwhile we can extend and patch the deck so it completely covers the blades...something this 1950s beast never did :oops:
Thanks for asking
/ Brush Hog mods #70
I was in a place today that would have been a good test for it, to see if it could work circles around a skidsteer :LOL: I posted a couple of pictures in the other thread, good luck and keep us posted.
/ Brush Hog mods #71
It would. ;) That right there is the perfect place for these cutters. A simple 75HP tractor and a medium duty cutter would've taken care of it easily.
/ Brush Hog mods
I wonder what grade chain they used in their experiments too.
/ Brush Hog mods #76
Same thing can be said for blades, how many think to inspect blades after encountering something significant or just check them annually for normal wear? Of the people I know who own a rotary cutter, it's hook it up and go, only looking under it if something has tangled up like fence wire.
IMHO blades or chains are both dangerous if maintenance and simple inspections are part of it.
/ Brush Hog mods #77
Here is a picture of mine back in 2019. Around 200-ish hours on this set of chain. I run mine very close to the ground, so it tends to dig a lot and wear out faster. I would say 400 to 500 hours per set of chains is a good time frame, but depends on a lot things.
You can see how thin the chain gets on the end that see all the work. You can also see the cracked link I keep talking about. This how these chains wear out. The link gets so thin that eventually it breaks. People will often run them till they get 1 to 2 links shorter before they get a new set, basically reducing the cutting width till it's a bit too much.
I still haven't bought a new set, even though it's less than €30.
/ Brush Hog mods #79
And another,
/ Brush Hog mods #80
What size of chain did you end up going with? Looks small in that mower. Cables won't work very well because they don't really have much weight at all.
For anyone interested, here is one of these cutters working:
Also, how one of these mowers look underneath and on the top:
View attachment 809784 View attachment 809785
Those little chains 'round the edges are 'new to me' and an interesting feature. I also noticed the lack of a wheel on the back. I'd assumed 'they all had one.' Live and learn. Thanks for sharing the video ;)
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2021 KOBOTA SVL97-2 SKID STEER (A65053)
2021 KOBOTA...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2022 EZ-GO ELITE...
