Log splitter ?
/ Log splitter ? #1
BIKER BOB
Raymond, Maine
Mahindra 3215
Is this the right place to ask log splitter questions? I did not see a seperate section for them.
/ Log splitter ? #2
Probably "attachments" is more appropriate but I wouldn't worry too much. If you post in the wrong area the forum police don't give tickets. Just ask your question :)
/ Log splitter ? #3
Wrong place, they have very strict rules and will throw you off the forum. I joke, this is as good as any place.
/ Log splitter ?
I have an older Tractor Supply Huskee brand splitter that i seemed to have worn the hyd. pump out of. bought it used quite a while ago ( about 2010 ), there are no stickers or manual with it. I think it is a 22 ton splitter, the pump on it looks like a MTE brand according to the research i have done on it. It has a 6.5 hp briggs engine on it. How do i tell what gpm this pump is? there are no markings on it.Also can it be dis-assembled and rebuilt? any suggestions? Maybe a place to look for info or an exploded view.
/ Log splitter ? #5
This might work.
/ Log splitter ? #6
With the 6.5 hp engine a 11 gpm pump would be standard. Generally the pumps used on splitters are not rebuildable due to lack of replacement parts.
/ Log splitter ? #7
Many of the low HP splitters like you have with 6.5hp have a 11gpm pump. My splitter has 10.5hp and has a 16gpm pump. A small engine won't pull the bigger pump.
/ Log splitter ? #8
Yup, 11gpm 2-stage.
And they are cheap to buy the whole pump....so it usually dont make sense to try and rebuild. Unless its something simple like a leak at the shaft. But a "worn" pump.....even if you could find replacement parts....it would likely cost more than a whole new pump
/ Log splitter ?
Thanks for the replies. makes sense to just order one then. Found a speeco type for about 125 bucks! Thanks again, I knew someone on here would have info.
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
1143 (A63745)
1143 (A63745)
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2020 FORD F-350 (A65643)
2020 FORD F-350...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
