Found a unicorn - Vermeer BC906
   / Found a unicorn - Vermeer BC906 #1
Whitbread
Massey 1740M
My side job tree work has turned into enough that my woodmaxx wm8m just wasn't keeping up and was clearly not enough for the volume of brush I needed to deal with. At the last tree job I did, my friend brought over a morbark 9" unit that he had to "test" after doing some engine work on it for his neighbor. As expected, the difference was night and day even though I had more hp and could chip a physically larger in diameter piece before I bogged down.
So I began hunting for something larger, but still a 3pt unit as the portability/maneuverability is invaluable to me.
Last week I found a BC906 listed in central PA. I was already going to upstate NY for a friends birthday party so the 3 hour detour worked perfectly. He was the original owner and was retiring from a landscaping business. He gave me all the manuals, spare blade set, and even a VHS safety tape haha.
The only oddball part is he had the dealer mount it on a trailer so he could just pin it to the draw bar instead. It worked perfectly for me picking it up though as I just bolted a 2" coupler onto the channel mount and it saved dragging an empty trailer on the way out. I'll get it cut off this week and turned back into a 3pt unit.
Just in case there's any towing safety police here, the hitch on the car is the factory euro hitch rated for 4klbs, car has helper bags in the rear coils, it's a tuned diesel that makes 600lb/ft at the tires, has larger brakes than a pickup truck, safety chains were hooked up, and magnetic lights were installed on chipper. Averaged 21mpg at 70mph with the cruise set on the freeway. Was comfortable as can be.
   / Found a unicorn - Vermeer BC906 #3
Just in case there's any towing safety police here, the hitch on the car is the factory euro hitch rated for 4klbs, car has helper bags in the rear coils, it's a tuned diesel that makes 600lb/ft at the tires, has larger brakes than a pickup truck, safety chains were hooked up, and magnetic lights were installed on chipper. Averaged 21mpg at 70mph with the cruise set on the freeway. Was comfortable as can be. View attachment 807925
What the classy foresters drive...
   / Found a unicorn - Vermeer BC906 #5
You sure you want a 3pt mount? Of course you know your needs, but if you leave the hitch on and tow it with tractor, it’s super easy to connect/disconnect that way. Can still be towed the way you towed it, too.
You also might find it handy to back the chipper up at an “angle” sometimes.
   / Found a unicorn - Vermeer BC906 #6
I was thinking the same thing. That's a lot of weight for a 1620. That thing looks like it's supposed to have wheels under it.
Does the car have economy PTO?
No, the original owner didn't check that option box :rolleyes:
Yes, I haul my tractor over to the job on the gooseneck. With the vermeer setup as a tow behind like it is now, I'd have to make second trip or have someone follow me as it would be over 32' long all hooked up on the deck with the grapple on the loader. In 3pt configuration, I could also haul one bunk of logs on the trailer in addition to the tractor and chipper when the job is done. On the jobsite, being able to get into tight areas and shortest overall length is worth its weight in gold to me.
Woops, guess I need to update my profile. I have a massey 1740m now. It lifts 2535lbs at 2' from the pins on the 3pt, so it should handle it. Chipper is listed at 2180lbs. It's definitely on the big side, but anything over 5" is firewood to me so the 9" capacity simply means WAY less brush trimming over my Woodmaxx.
Here's what the 906 normally looks like without the trailer option.
   / Found a unicorn - Vermeer BC906 #8
Nice score! I bid on a couple of them through online auctions, but they went for crazy money, in my opinion.
I ended up with a Vermeer 935, that "runs and operates" according to the ad.
I haven't seen it run or operate yet, but I guess it runs on dirt, rust, sediment, and old kerosene, since that's what was in the fuel tank!
   / Found a unicorn - Vermeer BC906 #9
I had it's little brother, the 606. It's one of the heaviest duty built chippers you can buy. For commercial work, it's excellent, for personal use, it's even better. They can sit around for years with no use, fire it up, and good to go. Vermeer stopped making the 3 point hitch versions because they weren't selling enough of them, and the 606 was $10k new back then (early 2000's if I remember correctly) so the 906 was even more.
I sold mine (one of the few implements I've ever sold) but if I ever found the need for another chipper that's the one I'd hunt for.
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
202480 (A54757)
202480 (A54757)
