Hydrostatic Tractor
/ Hydrostatic Tractor #1
Junkman Joe
Cub Cadet 7195
Looking for a used sub compact tractor, 30 hp. That is hydrostatic heel/tow controlled.
I’m handicapped and currently have a Cub Cadet 7195 19 hp. with heel/toe forward and reverse controlled tractor.
I have bolted a flat metal arm on the heel/toe so I can control the tractor with my hand.
Looking for a bigger tractor with the heel/toe control.
Can someone tell me if there are any used 30 hp. Tractors out there and the brand name.
I have talked to two fabricators to try and make something work for the two pedal control tractors, but they can’t come up with any thing that can work smoothly and have room for my foot and the loader controls.
Can anyone give me a name of a tractor that I can make work for me.
/ Hydrostatic Tractor #2
Kubota L3301 HST will have the treadle pedal control. The earlier L2800HST might have it, but I don't know for sure.
/ Hydrostatic Tractor #3
Welcome to TBN! There are many foot pedal hydrostats out there and available. I am most familiar with Kubota that have a treadle pedel and models like L3901 and 3301 are similar. For used 30 HP try to find one "pre-emission" model 2012-14 vintage with a few hundred hours - Kubota, Kioti are some of the more popular brands, but look at others too.
Then as far as actuation of the treadle, you can get a small 12V linear motor with a toggle switch to push/pull the treadle, or you can have a mechanical setup too. I would suggest going out and looking at several dealers machines and trying them out to see how you fit and how they will work with you to meet your needs.
/ Hydrostatic Tractor #4
Junkman, not addressing your questioin, but important. In compact tractors, hydrostatic transmissions use 7 - 9 of the available engine horsepower. Your 30 hp tractor may have only 23 hp at the PTO. If you'll be using the PTO to power finish mower, bush hog, etc., the recommended horsepower will likely be higher. Look at 40 hp tractors
/ Hydrostatic Tractor #5
I think all small Kubota tractors including the new models have a treadle pedal. Other manufacturers are going away from that style but their used models may have it.
The Grand L 60 series have a drive-by-wire HST pedal which may be even easier for you to adapt. The smallest is the L3560. In used models the previous Grand L line was the L40 series which also had the drive-by-wire HST. The smallest one of that series was the L3240.
/ Hydrostatic Tractor #6
My 35 engine hp 4410 looses 1.5 hp to the hydrostatic transmission vs the geared model. And I would suspect that that is only under heavy tractive loads like plowing or other kinds of tillage. When it comes to lighter pulling loads like mowing I doubt if it makes much difference at all. Certainly not enough to avoid a hydrostatic transmission. The pto to engine link is a direct mechanical connection on virtually all small tractors. The hydrostatic is for forward/reverse motion only.
I like the idea of modifying a drive by wire system. For one thing it opens up the choices to more than just treadle controlled tractors. Somebody smarter than I should be able to figure how to accomplish this. You could leave the tractor stock and just tie into the wiring with a conveniently located joystick like control and have a pedal/joystick switch to switch from one to the other. Maybe the joystick could be installed in series and you wouldn't even need a pedal/joystick switch. Like I say, somebody smarter than I am.
/ Hydrostatic Tractor #8
I was thinking of the drive-by-wire treadle as being easier to operate by hand with a lever. The HST pedals on my Branson can require a pretty heavy foot when there's a lot of force involved, like going up a steep hill.
Removing the potentiometer and using it with a dedicated hand lever would be even cooler, I didn't think of that.
/ Hydrostatic Tractor #9
How many 40 hp sub-compact tractors do you really see in your daily travels? How many sub-compact tractors can even safely lift or travel terrain with brush hogs or other implements requiring more than 23 HP at the PTO?
I have a Deere 3033R, which is 32/23 hp gross/PTO. It works great with loader, brush hog, snowblower, snow plow, plug aerator, and seed spreader. If I had to drive any more serious ground-engaging implements off the PTO, then the high HP (3046R) might be warranted, but you can do an awful lot with a 33 hp tractor.
To the OP, Kubota is where you'll want to be, for a solid machine with treadle control, good resale value, parts availability, and dealer support. Deere has a two-pedal control, with separate forward/reverse pedals. If you're more worried about up-front cost than resale, support, or availability, then there are other cheaper brands, but I'd stick to Deere and Kubota, myself.
/ Hydrostatic Tractor #10
I don’t think there are any sub-compact tractors with 30hp. 30 hp is getting into the compact category.
/ Hydrostatic Tractor #11
The New Holland TC33D and Case DX33 twins had the heal/toe pedal.
/ Hydrostatic Tractor #12
L2800HST did have rocker pedal,and it was pain if you wore big snow boots.
/ Hydrostatic Tractor #13
PMS - Tractor Data shows
Engine (gross):34.6 hp
25.8 kW
PTO (claimed):30 hp
22.4 kW (gear)
28.5 hp
21.3 kW (hydro)
30 - 28.5 = 1.5 So the "penalty" for a hydrostaic transmission is 1.5 hp. I'll take a hydrostatic over a gear for the work that I do.
/ Hydrostatic Tractor #14
Welcome to TBN...enjoy. :)
Kubota B models off HST with rocker pedal almost 30hp,if you go 30hp you have to deal with regen system.
/ Hydrostatic Tractor #15
Exactly. So why is any request for help in selecting a subcompact tractor being answered with a recommendation to "buy at least 40 hp"? Not very useful to the OP.
30 - 28.5 = 1.5
If I'm reading HTDT's example correctly, the engine HP was 34.6 hp. PTO horsepower was 30 for manual trans or 28.5 for hydro. So, in that case the hydro was burning approximately 6 hp, versus the gearbox at 4.6 hp. Irrelevant for any purpose other than showing that we can all do basic subtraction. :p
OP: I would call your local Kubota dealer in the morning, and ask when's a good time to visit to talk with an available sales person. They are the top brand running treadle pedal HST's, and likely where you'll land. I would also visit your local Deere and NH dealers, heck even the off-brands, as you're going to learn some things from each, which you should be asking the Kubota dealer before the deal is done.
/ Hydrostatic Tractor #16
On my Branson that is dual pedal you can pull up the forward to go backwards or pull back on reverse pedal to go forwards so might want to check if other brands allow this before writing off the two pedal versions.
/ Hydrostatic Tractor #17
And if you would have read what I wrote you would have realized that your statement was not relevant.
/ Hydrostatic Tractor #18
Guys, I'm not sure why you're wasting discussion on "gear vs. hydro", when the OP is specifically looking for a hydro tractor. I also don't understand the fixation on 1.5 hp differential, I just don't run into many situations where my tractor's horsepower is the primary limiting factor in getting a job done.
/ Hydrostatic Tractor #19
It might be worth checking with a business that does handicap van conversions. I worked for one briefly and they did some practical engineering to make vehicles drivable for people with limited mobility. Your are looking for a place that has a shop, not one that just sells vans with wheelchair ramps.
Doug in SW IA
/ Hydrostatic Tractor #20
Some of the makers already have an HST cruise control available. These may however have limitations for speed range of actuation.
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
