Base for Sawmill
/ Base for Sawmill
I got the track assembled and as straight and level as I think it will get. The instructions are good, but this reminds me of those old-fashioned stamped metal utility shelf kits where you'd get a zillion screws and square nuts, and had to put it all together. Tedious is an understatement. But it's together and solid as heck.
One section of track had a slight bow on the end, so I wrote Woodland Mills to see if I can get a replacement (I think I could bend it but I'd rather let them weigh in first). Other than that, the quality is very good and the track is very heavy duty. No missing fasteners or parts (yet). Need to begin assembling the saw head next.
/ Base for Sawmill #23
Great job and it looks very solid. :thumbsup::thumbsup:
/ Base for Sawmill #24
My sawmill has been sitting on concrete blocks with a 2x lumber between the mill and the block, for years and years! It's easy to do yearly leveling too, and it works just fine!
I have no problem milling out accurate lumber, or even veneer if I want...
SR
You have any pics of your setup
/ Base for Sawmill #26
SR, can you elaborate on the setup with your crank winch and how you use it?
I'm using my Frostbite grapple to turn really big logs but doing that is getting old ...
/ Base for Sawmill #27
The winch can be used with ramps, to parbuckle logs onto the mill, or turn logs as needed.
I only use the winch to turn big logs, it works great for that.
SR
/ Base for Sawmill #28
Thanks. Did you fabricate that or was it a sawmill factory option?
/ Base for Sawmill #29
Interesting this topic came up. Just the other day a guy delivered some rock to my place and wanted to pay good money for my mill, that has sat idle for over a year. I checked on used/new prices and wow the price of these things has gone up.
/ Base for Sawmill #31
I think that many of the mills with hydraulic log handling are months out. Not long ago it was a year or more.
/ Base for Sawmill #32
So here is what I came up with for a 26" wide, 20' long base:
All made with 4x6 timbers. I used scraps for the leg posts and just had to buy timbers for the tops. Cross-braces are also scrap lumber. All the gusset plates are scrap diamond plate steel, and it's all held together with galvanized 5/16" lag bolts. So I spent $100 on timbers, $35 on bolts and washers, and the rest I already had. Some people think it's stupid to keep 2-3' scraps of lumber but I always hang on to those pieces and it came in handy here.
I pre-fabbed each of the three sections in my barn on the concrete floor, to get everything nice and square, then carried each section to the site and blocked it up over the post holes to level it prior to pouring concrete around the posts. The posts go down 17-20" (below the frost line of 12").
Takes about 120# of concrete for each post hole. I'll finish pouring the concrete tomorrow, then give it a couple days to cure before I begin assembling the sawmill track on top.
I also drilled 4 post holes to support the roof that will be built over the top. That will be 10' wide and 26' long when done. Other than treated lumber for the posts, all that lumber will be felled and sawn on the fly. I am sure it will be interesting to build a roof frame with green lumber but I am looking forward to the process.
I'd prefer OSB and asphalt shingles on the roof, to match my barn and house, but if the price of OSB is still insane in a couple weeks (as I expect) then I'll just order some metal roof panels. Right now OSB+Asphalt will run me about $1.75 per square foot, and metal will cost $1.00 to 1.10 per square foot.
Nice looking base. I just sold my old Baker Wood Buddy and took delivery of a new HM122. Haven‘t even opened the box yet. I’m trying to decide if I want to try my hand a welding and build a trailer.
/ Base for Sawmill #33
Could I get an update on this mill? Maybe some pointers?
I just helped my neighbor fire up his new HM122. The log clamps wont fit a large log (20") won't go wide enough. Then they are pointed and make a hole in the wood when you do get the log small enough to fit. Even when you get the log smaller, the saw head won't clear the clamp. What the heck?
/ Base for Sawmill #34
I dug down past the top soil. Packed the clay with a tamp. Then put down 16 x 16 x 4 concrete blocks at each foot. Its been there a year. Only issue i have had was after a month straight of rain. I had to relevel it. You could do that to start. Cut yourself some heavy beams to go on top the base of blocks to raise as needed.
/ Base for Sawmill #35
The clamp head may be on bar upside down/backwards. Check its orientation. Its easy to do.
/ Base for Sawmill #36
Thanks, I did look at that and if we flip it, it will go a little bit wider but still not enough for a large log. Then the wider the setting the more it interferes with the saw carriage. It won't clear until you get down to about a 14" cant.
We moved the front one to get past it, then reinstalled it then removed the rear one but that lets the log/saw vibrate.
Not sure what I am missing here. I looked at some videos and it appears that this is a problem on big logs.
/ Base for Sawmill #37
Mine is still crated and stored in my shed…too many other projects and family stuff going on. Plus the fall fishing hasn’t been too bad. Now we have deer season coming up. Looks like springtime before I assemble mine. I have been accumulating parts for a trailer build though.
/ Base for Sawmill #38
This guy used 4" square tubing, about 3/16's wall, I think. He said he went a little too tall with it, it is hard to reach the crank on the carriage.
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
JMR 4ft Tree Boom Skid Steer Attachment (A64553)
JMR 4ft Tree Boom...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
1993 Brenner 307 SS Insulated T/A Chemical Tanker Trailer (A64194)
1993 Brenner 307...
2014 Ford Explorer AWD SUV (A64557)
2014 Ford Explorer...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
