rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,973
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I've always wondered just how much influence that air has in cylinders for FEL and hoes. It seems like cylinders repaired and replaced should put enough air into the system to have some effect - particularly with cylinders where one end is always up....or when replacing a big old BH boom cylinder which weights hundreds of lbs and has gallons of capacity. After a new seal job it has no fluid in it at all. All I can say is I've never been able to tell any difference.Sounds like cavitation to me (AIR)
As near as I can tell, the hydraulic fluid purges the air instantly. Just for drill, I do cycle the cylinders after replacing one and am curious enough to lean in to try to spot any difference due to air. But if it happens it is over so quickly I've never noticed anything specific. And I've been doing this a long time.
Just because it hasn't happened to me doesn't mean it can't.
rScotty
