Rotary Cutting Need to Knows!
   / Rotary Cutting Need to Knows! #1
Ridonkulus
Western KY
Zetor Major HS 65
I’m a new tractor owner and my next purchase is a rotary cutter. Naturally I have tons of questions before buying any type of rotary cutter. Before I make a post is there a post somewhere that lays out the need to know info before setting out to spend thousands of dollars. TIA
   / Rotary Cutting Need to Knows! #2
Is there a thread that lays out Rotary Cutter requirements?
   / Rotary Cutting Need to Knows! #3
Sep 26, 2019 / Newbie Question on Rotary Cutters
I have 60 acres (50/50 split timber/field). Im thinking that an 8' cutter would be a great size for the mowing. Im curious how many acres you guys mow and with what size cutter/tracker? Also how long does it take you? Curious if I can get away with a smaller cutter and save some money without it taking me an entire weekend, sun up to sun down, to get the job done. Thanks in advance.
Edit:
Mowing is probably not the right word. I only plan to brush hog it 3 maybe 4 times a year.
What has changed since September 2019?
   / Rotary Cutting Need to Knows! #4
There are many considerations. We need more information to make more than a general recommendation.
What make/model tractor.
What exactly are you cutting? Grass, weeds, brush, sm trees? What is the greatest diameter ?
What kind of terrain? Hilly, flat, Steep ?
none
Add your tractor brand and model to your T-B-N PROFILE.
thanks for the link. I will look this over and any specific questions I have Ill start a new thread.
   / Rotary Cutting Need to Knows! #6
No need to start a new. Take a minute and put your tractor in your profile too (y)
   / Rotary Cutting Need to Knows! #10
Good info, and/or reminders here on #8.
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
Stump Bucket (A50322)
22ft Progressive Finish Mower (A52128)
22ft Progressive...
