rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,977
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
BTW, which one is the relief, the #1 or #2?
I agree with ptsg. Number 2 seems to be the relief value - but I'm puzzled by the location. Still, if you put your hand on that control assembly and do not notice some sort of vibration when the motion of the BH stops, then I'd say that your relief valves are OK. I don't think you would miss the vibration of the relief valve working.
The support for the idea of the connectors is simply that something seems to be interrupting the flow and the connectors do have the ability to do that. The hydraulic force is going to be able to move most anythng else out of the way. I don't see anything that tells me those connectors are inexpensive or otherwise... and don't know of any way to tell. This is just speculation on my part because what you are having happen would make sense if a spring/ball blocking setup went bad.He says he never had such an issue and this suggestion came from TYM.
Also, what supports the idea of the connectors, the problem started with 2 stops per swing every 1/3 of the way. After i disconnected and connected the BH it changed its behavior and now it makes 5-7 stops.
I checked the connectors inside, they look like new, no dirt, no rust no anything else.
Hopefully tomorrow i'll be able to get new connectors and install them
Are you saying that that those ones are not good connectors? Which ones should i buy and how can i see the difference between the good ones and bad ones?
Also, i took a picture of the connection where the hose is connected. I guess it is PB point?
The fact that it chanced when you disconnected and reconnected them sounds pretty suspicioius too.
BTW, if that device #1 is indeed a check valve as ptsg says.... then we have to include the check valve in the list of possible culprits. First I would confirm that the hose to #1 is the input pressure - if your hoe is plumbed like we think, that hose should come back from the front loader control valve PB port.
If so, see if tapping on the check valve changes things or if you can feel a vibration there.
If nothing works - but I'm hopping it will - then the next thing will be to remove that check valve or plumb it solid without the quick disconnects just to see if it works then. That may need putting in a dummy or different valve to make up the space.
And after that...if still no luck, make up a test gauge you can insert into the line. Not sure why.... It will be a T connector with quick connectors on each end and a guage in the center of the T connector. Whole device costs maybe 50 to 75 bucks to make up. Use a 0-5000 psi pressure gauge - usually that is a $30 item.
I'm banking heavily on the connectors or check valve. After that I am running out of simple ideas...
luck,
rScotty
