Bend User
- Joined
 - Jun 6, 2023
- Messages
 - 1
- Tractor
 - No ATV 145
I ordered this piece of equipment less than a year ago, and after about 10 hours of usage I have had the following problems:  Belt failed because it was installed upside down from the factory and it comes with three belts.  The belts are impossible to replace.  The tensioner does not loosen enough to get new belts on or take off.  I suggest buying replacements a 1/2 inch longer.  Also, the tensioner bearings went out and that has to be replaced.  The grease zirks are located inside the tire for the rotating drum and impossible to reach without a 90 degree coupling.  I also don't think that the mow quality is all that great.  I believe that I got mulching blades, but don't remember.  This is a Chinese built POS.
