BestCo Flail Mower ATV 145
   / BestCo Flail Mower ATV 145 #1
Bend User
No ATV 145
I ordered this piece of equipment less than a year ago, and after about 10 hours of usage I have had the following problems: Belt failed because it was installed upside down from the factory and it comes with three belts. The belts are impossible to replace. The tensioner does not loosen enough to get new belts on or take off. I suggest buying replacements a 1/2 inch longer. Also, the tensioner bearings went out and that has to be replaced. The grease zirks are located inside the tire for the rotating drum and impossible to reach without a 90 degree coupling. I also don't think that the mow quality is all that great. I believe that I got mulching blades, but don't remember. This is a Chinese built POS.
   / BestCo Flail Mower ATV 145 #2
Hello Bend User,
I am sorry to learn of your poor experience with this attachment.
This machine has a one year warranty, it may be better to pursue obtaining a replacement machine or to simply scrap it and invest in a RAMMY atv/rtv flail mower.
   / BestCo Flail Mower ATV 145 #3
Hello Bend User,
Yes, they offer one year warranty.
   / BestCo Flail Mower ATV 145 #4
Their ATV mower is the very old version which is more than 10 years. They don't understand this mower, the only improvement they did is that made the wheel assembleable to save delivery cost.
I m surprised why they didn't improve anything, you can see how it looked 10 years ago, almost same. They must have more or less feedback from buyers. For example the belt issue, that belt tension design is very old and stupid, three belts have different tension when work, so the belt is easy to be burnt.
Our ATV mower has changed a lot these year.
   / BestCo Flail Mower ATV 145 #6
Can you use an ATV/RTV front mounted RAMMY flail mower instead??
The RAMMY distributor METSA Machines is in Michigan.
   / BestCo Flail Mower ATV 145 #7
Kunz Engineering builds a helluva mower. 27hp, 57” cut.
   / BestCo Flail Mower ATV 145 #9
I didn't think this was a rough cut machince. Or did the OP want a rought cut mower?
They sell both. The rough cut actually cuts nearly as well as a finish mower
   / BestCo Flail Mower ATV 145 #10
Last time I looked at Kunz rough cut mower, they didn't offer free swinging, down set type of blades. I called them and spoke with mr Kunz and he siad they made the blades from "special super steel" and could take the abuse. We didn't ordered it. Have they changed this setup?
ROME GK-14 LOT NUMBER 131 (A53084)
ROME GK-14 LOT...
JOHN DEERE 4730 LOT NUMBER 268 (A53084)
JOHN DEERE 4730...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53472)
Adams Load Out...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
LMC LOT NUMBER 139 (A53084)
LMC LOT NUMBER 139...
