VFD-Need Help Identifying Terminals
/ VFD-Need Help Identifying Terminals #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Been using this VFD to power a buffer for several years and now wanting to use it for a three phase motor on my lathe. I'm curious what the terminals are for that are circled in red. Any ideas? TIA
/ VFD-Need Help Identifying Terminals #2
Picture is really blurry
+ and - on a VFD typically is the DC bus internally.
Did you click on the thumbnail?
The four terminal markings left to right are: (/) +1 + -
The two middle ones are jumpered together.
It is a Polyspede brand but they were apparently acquired by Hitachi. The Polyspede number is XLT5-20 (2.0 HP) and the Hitachi number is L100-015NFU. I have the manual as well as a quick reference manual but neither show these terminals.
I'm wondering if those terminals are for an external braking resistor. Would that make sense?
/ VFD-Need Help Identifying Terminals #7
That's pretty common as well.
Normally the manual will spell out what the terminals are.
/ VFD-Need Help Identifying Terminals #10
Uh, on most of these type devices, they aren't for you to mess with... :)
Truly, Stick with the front terminals. Just sayin
Page 5-2 shows some components on the terminals in question although I don't see the one marked (/) in the first post picture.
I doubt that any additional braking resistor will be needed on this 1.0 HP lathe application. I'm guessing that deceleration rate can be adjusted to make thread die and tap die reversals quick enough. Single point threading up to a shoulder can require a quick stop if the half nut isn't operated for each pass.
/ VFD-Need Help Identifying Terminals #13
Do not hook anything to the dc bus and make sure it is good and discharged before you touch it. Once the charge light goes out your ok to touch
So, you're saying that the terminals shown in post no. 1 are the dc bus?
/ VFD-Need Help Identifying Terminals #15
Yes , ac voltage is marked l1,l2,l3 on incoming and u,v,w on outputs. +,- are tue dc bus.
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
2012 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2012 CM TRAILER...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
