674 diesel fuel return line
/ 674 diesel fuel return line #1
domains
Mines leaking, No pressure in the return line, I found black vacuum pipe in shed right size no more leaking , but friend tells me diesel will eat it up, but said he was not sure
Anyone know? thanks , its the really small pipe model, OEM has breaded cloth over pipe for no expansion i guess
Where do you buy just the pipe and cut it to lenght?
Can I use an ATV gas pipe? pretty much same size
/ 674 diesel fuel return line #4
Go to an auto parts store and purchase fuel line, hose clamps and steel brake line
steel brake line? why
Its a very small pipe 1/4 inch thick
/ 674 diesel fuel return line #7
You asked for pipe and it comes in smaller diameters such as that for fuel line. ATV or plastic line would probably work too, just don’t know how rigid it would be to clamp
I never saw a 1/4 inch clamp before but see them online, I used rabbit snare wire but one of the old pipes was leaking from a small hole, The big return fitting , not sure how to get on with heat or maybe soak in fuel 24 hours , heres a pic of it new
/ 674 diesel fuel return line #9
Hose clamp, BUT alot of times you can squeeze fuel line on the leak off barbs and they won’t leak eliminating the need for clamps
They want 250$ Canadian for it shipped, its 150usd , maybe rare or hard to get that pipe on the bigger long fitting, Maybe try and get an addaper to make the pipe smaller?
Found real Tubing , its metric , When you take pipe off the shaft theres a small fitting under it :)
Cost me 8$ to fix, almost cost me 250
Found at a volkswagen dealer
Lady on phone tried to take my money without telling me shipping and boarder fee, was missing 5$ on the card, She called me and I said il go put more money on it, then thought frig that im not paying 265$ for a pipe with a few fittings I already have
/ 674 diesel fuel return line #13
Can't you just piece it together with fuel line from the auto parts store? You are making this a major project!
I found the real piping, the parts guy at kubota dealer told me the IH guy gets the pipe at the volkswagen dealer, its fixed, no clamps needed
My friends 574 has a bigger pipe, strange, he almost lost all his fuel last year, got home just in time, he opens winter driveways like me, same issue
I got my fuel pump all gasket new, with orings last year, I thought my fuel leak was fuel on top of motor from bleeding the injectors but it leaked all winter, so i'm glad that issue is fixed
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2019 GMC SAVANNAH 3500 14' BOX TRUCK (A65054)
2019 GMC SAVANNAH...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2019 CATERPILLAR 316FL EXCAVATOR (A65053)
2019 CATERPILLAR...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
