bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,923
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I have an older, heavier duty version of that same trailer. It uses the same type tailgate which does indeed become difficult to remove with a load against it. Loading the trailer at the front helps but depending on the weight, it can overload the hydraulic cylinder and make dumping difficult. I eventually modified the tailgate by welding hinge tabs on the outside and now use easily removeable pins to hold it in place. It wasn't a difficult job but welding skills are necessary.
A word of caution when using a compact tractor to move a heavy trailer. Most CUT's only have rear brakes and it's very easy for the trailer to get away from you on hills. When in doubt, I always back the tractor & trailer downhill.
Yes, you do have to pull away from the pile at full dump to completely empty the trailer. Depending on the material you're hauling, it can clump up and stick in the bed. A bed liner can ease this problem considerably.
I have a 7 pin connector on my truck which will charge the battery but I leave it connected to a battery maintainer when I'm not using the trailer.
