snpower
Gold Member
- Joined
- Nov 12, 2010
- Messages
- 467
- Location
- Charlottesville, Virginia
- Tractor
- John Deere GT235, GT 275, 1025R
Symptoms are PTO not engaging or engaging and then disengaging at random times.
I have followed the WSM to check the PTO switch and the current draw coming out of the harness side. The switch matches battery voltage, the current draw is 2.2 amps which is a tad below the range specified.
I believe I have a bad "blue: wire; moving it by hand with the PTO switch ON results in the clutch engaging. I'm not too sure/confident about how to run a new wire//bypass the existing one, looking for input. I did price out an entire wiring harness for the tractor which is pricey.
Thank you.
Thank you.
