GT275 PTO Engaging Intermittently
/ GT275 PTO Engaging Intermittently #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Symptoms are PTO not engaging or engaging and then disengaging at random times.
I have followed the WSM to check the PTO switch and the current draw coming out of the harness side. The switch matches battery voltage, the current draw is 2.2 amps which is a tad below the range specified.
I believe I have a bad "blue: wire; moving it by hand with the PTO switch ON results in the clutch engaging. I'm not too sure/confident about how to run a new wire//bypass the existing one, looking for input. I did price out an entire wiring harness for the tractor which is pricey.
Thank you.
/ GT275 PTO Engaging Intermittently #2
Your choices here are pretty much 1) weak battery 2) intermittent switch 3) harness issue 4) worn clutch. You can run an Ohm test on the clutch itself, I'd have to dig on spec. Is the outside ring on the clutch adjustable? Too much of a gap can be an issue. If it was, it would have 3 nuts.
I would have thought if wiggling a wire caused it to engage with the PTO switch checking out OK it would be in the wire.
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
STORAGE FEES (A59904)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
