snpower
- Joined
- Nov 12, 2010
- Messages
- 468
- Location
- Charlottesville, Virginia
- Tractor
- John Deere GT235, GT 275, 1025R
I am about to drop this machine off with my small engine guy but thought I would ask for additional thoughts prior.
My GT275's PTO will not spin. I replaced the old switch with a new one for good measure - no change. The switch has proper continuity per the maintenance manual checks. I checked for current/amps at the harness side, everything was within limits per the mm once again. I pulled the PTO off the machine, cleaned it thoroughly and hooked it up to 12 volts power - it fires as it should.
My symptoms now are: Engine will try and stall with the PTO switch in the ON position, with either (1) me getting off the seat, or (2) releasing the parking brake.
Any thoughts appreciated.
