GT275 Engine Surging
   / GT275 Engine Surging #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I have my father's GT275 in my possession; It has been at my mother's property and would not turn over or start. I replaced the fusable link, and the seat switch to resolve that. It starts normally, but the engine surges. The RPM's drop somewhat about 3 - 5 seconds. It is worse with WOT and when you press on the hydrostatic pedals. I filled the tank with fresh non ethanol gas, poured in some seafoam, and let the engine run for probably 75 minutes and also mowed my yard with it. It seems fine save for the surging which is again, worse at WOT and when accelerating.
I do know that the machine was serviced by John Deere 1.5 years ago. The fuel tank and system were drained/cleaned and I believe the carb was cleaned but I am not 100% on that.
Thoughts on what I should check?
   / GT275 Engine Surging #2
Carb is gunked up. Time to take it off, take it apart and give it a good soak in something like Berryman's Chem Tool and put it back together. You have a partially plugged main jet / emulsion tube.
   / GT275 Engine Surging #3
As 5030 says likely carb - you can clean bowl and jets, but I had cleaned/fixed the Kohler Magnum carb on my 35 YO Cub cadet several times, so decided to try an inexpensive replacement carb for $30 - after replacing it starts much easier (fires off in seconds vs cranking for 15 seconds) and runs better.
5030 was correct! I thought that might be the direction to go but was glad to have confirmation. So, thank you both for replying.
Pallet Fork Backing/Spear/Reese Hitch Combo (A47371)
Pallet Fork...
2008 Ver-Mac PCMS-1500 S/A Towable Solar Message Board (A46683)
2008 Ver-Mac...
Erskine QA Snowblower (A49251)
Erskine QA...
2017 Ford F-150 XL 4x4 Ext. Cab Pickup Truck (A46684)
2017 Ford F-150 XL...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A46683)
2017 JLG Skytrak...
Uline Dock Plate NEW (A47369)
Uline Dock Plate...
