Top Link Indicator
/ Top Link Indicator #1
SEJones720
none yet
Hey everyone! This is my first post, and I hope someone can give me some thoughts and ideas. I have watched the Dave Knows How videos on setting up a box blade and especially the one about making up a hydraulic top link indicator to see at a glance if your box blade is level and in a neutral position. However, I’m not a welder. So I’m looking for ideas on how to cobble together a rod attached to the top link cylinder and riding thru a loop or eye bolt mounted on the top link rod. If you’ve done such a thing, pictures would be great!
OR…would it be simpler to just draw a line around the top link rod at the neutral position with a magic marker? Is that something can be done without damage to the top link? Any thoughts would be welcome.
I have a Kioti DK4210SE.
Thanks.
/ Top Link Indicator #2
Just a suggestion. Try looking at the implement instead of the top link cylinder.
In reality, it really does not matter where the rod is, everything is related to the implement and the ground.
Thanks for the thoughts guys. I’ll give something along those lines a try.
/ Top Link Indicator #6
This way may be crude, but it works great. Didn't cost much.
Nice ! I've got a similar metal flag mounted on the top of my FEL bucket that simply repeats the angle of the bottom of the bucket. It's just an eyeball aid, but it is visible when the bucket bottom is not. Real handy.
/ Top Link Indicator #7
You can't draw a line around the rod. Well,,,,, you can,,,,, but it will be wiped off the first time the cylinder collapses past the line.
I'm not sure you will benefit much from an indicator on the top link. As others have stated, you'll get more good from watching the implement.
I built an indicator for my side link. I was very excited about it. I never use it. Instead I look at the result I'm getting to determine if I need to change tilt.
But it might give you ideas.
/ Top Link Indicator #8
I see what you are trying to accomplish with a indicator... But that experience comes with more seat time.. if you were doing some very fine grading for sand or something really important I can see it.
You want a simple version attach a small rod, yard stick anything that small enough to attach above the eye of the top link and point back towards the cylinder.. adjust it with the blade level to the point when it crosses plane with the cylinder that will be your level point. Seems more logical since you spend most of the time looking back... down towards the work the blade is doing.
I would suggest sitting in seat and looking back to get it to the point you desire before attaching by tack welds or other means.
A small rod, maybe a small clearance block of steel a nut or pipe to run it through and maybe a nut on top of you want it adjustable... You can drill a hole tap it or weld a smaller nut on top with a set bolt.
Just make sure it has clearance above the cylinder and won't make contact with it or hydro fittings when let in all the way.
Red clearance block if needed, blue pipe or nut, pink rod, green set point for adjustment
Small tack welds on that rod end is fine you're not getting anything hot enough to worry about.
/ Top Link Indicator #9
Just make sure it has clearance above the cylinder and won't make contact with it or hydro fittings when let in all the way.View attachment 796105
The reason I have my level the way I do is I'm 76 years old and have bad arthritis in my spine. Also from my sitting position the blade on the box blade is blocked by the frame bar.
Before I had this I had to get off of the tractor to see and adjust it.
I ended up having to buy a zero turn mower, because I couldn't turn around to and back up to my mower or boxblade and hook them up.
/ Top Link Indicator #10
Don't worry about the position of the top link. Look at what the implement is doing on the ground and make top link adjustments accordingly.
/ Top Link Indicator #11
Here's why I like the level, every year there are a few anthills in the yard and a lot in the orchard. I just set it to zero(level) and it only cuts the anthill.
Like I said before it's crude, but it works perfect for me.
/ Top Link Indicator #13
Thanks.
I haven’t tried it yet, but I’m thinking how to use a “choke cable” that when attached to the cylinder will actually show position of the cylinder regardless of the angles that I have everything at.
I’m also looked at the idea of using a “water tube level”.
I can say more if that’s not clear.
/ Top Link Indicator #15
Spending more time on youtube and less seat time on your machine makes you a better operator
/ Top Link Indicator #16
I think that anything to do with a bubble level would be next to useless. The only time it shows anything relevant is when the tractor is level. That doesn't happen much when I'm using my tractor.
The "choke cable" idea shows promise but you need something that matches the stroke of your hydraulic cylinder.
I built my own box blade. It's not pretty because I built it with what I had on hand at the time. It has an 8" rolling pipe on the back which acts as my depth gauge. A quick look to the rear to see what the blade is doing tells me how to adjust the hydraulic top link to control my depth of cut on the box blade. I can use the box blade at speed and not worry about it digging in.
/ Top Link Indicator #17
Some top links sold out there (usually the bigger ones, Cat 2+) have a built in scale and indicator rod. Shouldn't be too hard to recreate the same thing.
/ Top Link Indicator #18
[...] However, I’m not a welder. So I’m looking for ideas on how to cobble together [...]
I'm not either. And I didn't feel like trying to bum a job off of the people I know who are.
I found a machine shop near me that was happy to do a welding job for me, which they did pretty quickly for $60. It was a very good experience, and now I think "well, I could get it welded" whenever I'm coming up with ideas. I look forward to the next time.
WAY less expensive than becoming a welder with equipment (if you didn't want to do that anyhow). I respect people who do, and if I had more lifetimes I would definitely do so myself in at least one of them. But -- so many porcupines, so little time....
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
