trail clearing technique and tools
/ trail clearing technique and tools #761
/ trail clearing technique and tools #762
I've started clearing what was a trail for mules and horses, but am unwilling to take my tractor into the area because of locust thorns. For the time being, I've been carrying my straps/ropes/winches/pulleys in a 5 gallon bucket.
Some kind of light two wheel cart would be helpful to carry the weight. Might have to build one.
When you don't have ready access to your tractor or 6x6, what are some tips for carrying what you need to work with?
/ trail clearing technique and tools #763
I use a four wheel Gorilla cart. fits most of my clearing tools. Even have a chainsaw carrier mounted to the side.
/ trail clearing technique and tools #764
I started clearing a TRAIL earlier this week. I used a 2 wheeled wheelbarrow (not shown) to pack all my stuff.
/ trail clearing technique and tools #765
I have a "1200 pound capacity" wagon that I bought from northern tool about 25 years ago.
I doubt it would hold up to 1200 pounds, but we used to take it to the fair and other fairgrounds events when the kids were small, toss them in the wagon at the end so we could haul them and all our picnic stuff back to the car; these days I use it for hauling firewood, or all of my fence tools when I'm doing medium-sized jobs that don't require the tractor. If it doesn't fit in the wagon (which is about 2'x4') then I either make two trips or pile everything in the tractor bucket and use it instead.
/ trail clearing technique and tools #766
I want to try to keep it lightweight. I have to cross a creek to get to the area where I'm working. And there are thorns that will puncture pneumatic tires.
/ trail clearing technique and tools #767
Maybe a sled with outrigged solid wheels. They go across water and mud.
Or one of those long equipment backpacks?
/ trail clearing technique and tools #768
ATV with foam filled tires?
/ trail clearing technique and tools #769
I have twin run flat tires on my WB. No worries
/ trail clearing technique and tools #770
I had heavy duty liners put in my tractor tires. That stopped the thorn flats.
What tools or equipment will you have with you?
/ trail clearing technique and tools #772
Bare minimum would be at least one Maasdsam rope puller, 50' rope, redirect pulley, strap, D ring, throw line w/bag, grapple hook/rope, Echo top handle saw, and a couple of bottles of water for me. I'd add a second puller setup for some of the work and may also carry a Echo PPF-225 pole saw.
I'm thinking of building a wooden wheelbarrow with oak handles, dual wheels from a lawn mower and 1/4 plywood for the box.
When we hike in, we use backpacks made for that task. All other times and we have more junk along, it goes in our machines box. You have a lot of items you'd like along so I don't have any smart ideas. If you have hills, carts or wheelbarrows could be problematic. If we had thorns, I'd dope the wheels on our 6x6.
/ trail clearing technique and tools #774
My trail survey yesterday. Many of the dead Ash have come down or dropped the larger branches, and of course most fell across the trail.. Still plenty standing though, even the bark is coming off them, not sure what's holding them up.
I foresee a lot of chainsaw work ahead.
Branch almost three times my height feel from top of ash and is firmly embedded in the ground.
/ trail clearing technique and tools #777
I like to make trails with my PT425 and 4' brush cutter for a start. It goes about anywhere I'd want to be able to walk, and takes down everything 2" or smaller to ground level. If there's anything larger than that, I drive around it if at all possible. Anything about 8" or so in diameter that I can't just shove out of the way with the PT425 that's lying on the ground, I just drive over and keep going. I'll come back later with a chainsaw and cut anything that's laying in the trail and push it to the side.
I've made about 2 miles of trails on our 20 acres in this manner. Works great.
/ trail clearing technique and tools #778
I went through a young aspen forest and that was hell … (see pictures attached) it was so thick you couldn’t even walk through it… i had to cut slash on the side of the trails to have a place to throw the aspen in … it took a lot of effort and time … usually the easiest is to stay in the mature forest it is more open, there are only branches tu cut … in my case I didn’t have a choice …
Looking at this summer trail work today. On a side note, I'm negotiating with the Monks at the Society of Saint John monastery about clearing thier trails this summer. Ya, these are all what we groom.
/ trail clearing technique and tools #780
Are you going to be paid with pastries and jam?
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
CAT 953 Crawler Loader (A61166)
CAT 953 Crawler...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
2017 Caterpillar 336F Hydraulic Excavator (A61567)
2017 Caterpillar...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 23' LONG (A62131)
(2) BUNDLE OF MISC...
