Just an obsvervation about FELs
/ Just an obsvervation about FELs #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I have seen many pictures of Front End Loaders on Compact Utility Tractors on this site. Having one myself, a CUT with FEL, I have been paying attention to how they are constructed. And they are all pretty much made the same. Not just the geometry but the actual shape of the components. The bracing, gussets, and the prismatic tubular components. By prismatic tubular components I mean stuff like square or rectangular tubing that changes dimension along the length. So even though the tubing might be square or rectangular at any particular cross section the size changes along the length. So If I was to build one for myself I would just find one on a lot somewhere that is the size I want, or close to the size I want, take some pictures with a tape measure in the picture to use for scale, and copy it. No calculations. No wondering why a particular shape of gusset. Apparently the calculations have been done and work well enough for everybody else to use the same shapes and the same changes in dimension. This works for backhoes too. Just copy something similar. They are all using the same geometries too.
Eric
/ Just an obsvervation about FELs #2
Its about putting the strength/mass where it is needed, and not having the extra mass where it isnt.
You could build a loader like a tank. But that either adds to the load on the machine or reduces its capacity or both.
/ Just an obsvervation about FELs #3
But there is far more than just taking a tape measure to it. Welments that are concealed inside, size and type of welds and material properties are just some of the things that could add major differences yet go undetected. In the past before strain gauges or FEA they just added more material, or adjusted for failures later with updated designs. Now, an FEA report can be generated on a laptop in minutes, with materials and geometries that can then be tweaked, and a new report generated. Maybe that's why the designs now have converged to all look alike.
/ Just an obsvervation about FELs #4
I'd agree that a basic loader looks simple. Probably most important is to build a good full length subframe from front of the tractor back to the rear housing. With that done, adding a loader would be easier.
All our loaders have full length frames...my guess is all good ones do. There's still a little bit of room for innovation in FEL design. We have 4 loaders and each has a completely different way of tilting the bucket.... not counting the old JD that had a manual dump. With a bucket full of wet manure that manual dump could sure be exciting...
rScotty
/ Just an obsvervation about FELs #5
How do you know wall thickness? Can you get at it to measure it for all the pieces?
I can determine the wall thickness on my FEL. I assume that anybody that is gonna weld up their own FEL knows enough about fabricating something like this to have a pretty good grasp on how thick the metal should be and if they don't they would know how to find out. What I was trying to get across in my original post is that the design elements and sizes of all the FELs I have seen on CUTs have been virtually the same and that a person could save themselves a bunch of time by just copying one rather than trying to figure out all the lengths, angles, gussets, and braces. All this hard work has already been engineered and done by someone else. There are many folks here who like making their own stuff, I'm one of them. I just observed that all the FELs looked the same and if I wanted to build one I would take pictures with a tape measure in the pictures for scale and use the pictures as a design and build guide.
Eric
/ Just an obsvervation about FELs #7
I sort of agree with you in the case of loader arms that are square/rectangular section because they are unlikely to have any hidden features on the inside that you can't see. But any sort of arm that is more like '4 plates welded together' than '2 channels welded together' has a good chance of hiding something very important on the inside.
I'm definitely a big yes on the encouragement/DIY aspect of it. I have never heard of anyone who completed a DIY loader project and went 'ehh, you know that wasn't really worth it'. I think that's partially because if you build a loader for the first time, probably more than half of what you get out of it in the end isn't the loader, it's the rest of the manual and mental skills you developed along the way.
/ Just an obsvervation about FELs #8
Eric
That's more or less how I did mine. Just went ahead and checked lots of loaders in person on farm shows and other events, to get an idea on how it's put together, thickness of materials used, cylinder placement and sizing, hoses, etc. Did take some pictures but didn't really take any measurements.
Another trick I used was to find a picture of another tractor like mine that had already a loader, import the picture to a CAD software, scaling it properly, and then get all the dimensions I needed. Won't be fully dead on but will be perfectly close enough.
In the end, came out with my own CAD model to make sure I had all the right geometry, clearances, strokes, etc.
/ Just an obsvervation about FELs #9
SNIP......probably more than half of what you get out of it in the end isn't the loader, it's the rest of the manual and mental skills you developed along the way.
That's a nice loader. I especially like the bellcrank type of bucket tilt mechanism you made. That geometry is way more interesting than a straight connection.
Speaking of what we get out of projects, I have come to really like the late night part of figuring the angles, forces, and stresses. I used to build by eyeball, grinder, saw, and torch but without doing any of the trig.stuff. It took until later in life - about the time that the HP 28S calculator came out - for me to discover I had been missing fully half the fun of designing things. And it keeps growing. The mental imagining and pencil-sketching part is now a new favorite pastime.
/ Just an obsvervation about FELs #10
I had a direct connection to the bucket on my previous homemade loader for a Kubota B7000.
The only good thing about it, was the simplicity of it because it was only a single cylinder mounted in the center of the arms, so less hoses, fittings, pivot points and so on. Everything else I hated it. Couldn't get enough curl close to the ground, would go over center and bind at full dump.
Granted I was very very young when I built it with the help of my dad and we relied way too much on the "eyeball building technique".
It was also a fixed loader with no quick attach and with no good/easy way of taking it off, so it was aggravating at times.
On this one, even though I didn't modeled it, has the Euro quick attach which a breeze to use and can also take the entire loader in less than 5 minutes. Got a much more usable amount of curl down low and still a nice dump angle up high.
bad boy zero turn 72 (A56859)
bad boy zero turn...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
2014 FREIGHTLINER  CASCADIA (A60736)
2014 FREIGHTLINER...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A59317)
2025 GIYI GY-P45...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
