New owner Kioti CK 2610 HST
/ New owner Kioti CK 2610 HST #21
Not normal. Mine doesn't change sound whether the clutch in or out.
If you have the 4030C loader, the lynch pins will rattle and sound like an engine knock, but that's on either side of the steering column, not the rear end.
And ditto MiniDonkey22, the clutch is only used for starting and the PTO. It's nice to have as you can ease into the startup of an implement.
Hi Cioti, thanks you have a 2610?
/ New owner Kioti CK 2610 HST #24
Yep. Little over a year now.
/ New owner Kioti CK 2610 HST #25
I've had a 2610 for 3 years and no rattle coming out of the rear. Sounds the same clutch in or out, PTO or not.
/ New owner Kioti CK 2610 HST #28
FWIW, my 1985 deutz-allis 5220 hst has a clutch. The 2017 MF GC 1705 I am thinking of buying does not have a clutch.
/ New owner Kioti CK 2610 HST #29
Ok, I see now. That is weird… I’ve never seen a clutch on an HST. I have a 4-range hydro, but no clutch
Kubota has had clutches on hydros for many years. It isn't unique.
Go to the dealer and try another tractor on the lot- see if it has the rattle.
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2020 DRAGON ESP...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2018 John Deere CX15 (A60462)
2018 John Deere...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
