New owner Kioti CK 2610 HST
/ New owner Kioti CK 2610 HST #21
Not normal. Mine doesn't change sound whether the clutch in or out.
If you have the 4030C loader, the lynch pins will rattle and sound like an engine knock, but that's on either side of the steering column, not the rear end.
And ditto MiniDonkey22, the clutch is only used for starting and the PTO. It's nice to have as you can ease into the startup of an implement.
Hi Cioti, thanks you have a 2610?
/ New owner Kioti CK 2610 HST #24
Yep. Little over a year now.
/ New owner Kioti CK 2610 HST #25
I've had a 2610 for 3 years and no rattle coming out of the rear. Sounds the same clutch in or out, PTO or not.
/ New owner Kioti CK 2610 HST #28
FWIW, my 1985 deutz-allis 5220 hst has a clutch. The 2017 MF GC 1705 I am thinking of buying does not have a clutch.
/ New owner Kioti CK 2610 HST #29
Ok, I see now. That is weird… I’ve never seen a clutch on an HST. I have a 4-range hydro, but no clutch
Kubota has had clutches on hydros for many years. It isn't unique.
Go to the dealer and try another tractor on the lot- see if it has the rattle.
2002 FREIGHTLINER CST120 (A60736)
2002 FREIGHTLINER...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Kubota M1048A Forks (A60462)
Kubota M1048A...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2025 Kearney 7'X20' (A60462)
2025 Kearney...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
