New owner Kioti CK 2610 HST
/ New owner Kioti CK 2610 HST #1
801555
Halifax Nova Scotia
Kioti CK 2610 HST
hi,
I just took delivery of a new Kioti CK 2610 HST and noted a knocking/rattling noise in the rear end. (see attached video). When I push down on the clutch pedal the noise completely disappears, is this rattling noise normal?
/ New owner Kioti CK 2610 HST #3
Is the PTO engaged?
No way that is right. Shut it down and call your dealer.
hi, I called them right away and they picked it up next day, they are checking it over but are telling me the sound is normal
/ New owner Kioti CK 2610 HST #7
That doesn't seem right. But why does an HST have a clutch? My TYM is HST and I have go pedals and brakes... Why does Kioti have a clutch?
hi, it is required to start the tractor and change into H/M/L
/ New owner Kioti CK 2610 HST #9
Where do they put the clutch, when you have HST pedals and brakes?
/ New owner Kioti CK 2610 HST #10
Ok, I see now. That is weird… I’ve never seen a clutch on an HST. I have a 4-range hydro, but no clutch
its on the left side of the hump, brake on the right side of hump, forward and reverse pedals to right of the brake pedal
/ New owner Kioti CK 2610 HST #12
Looking at another video online, it seems it might be normal. You didn’t hear this when you test drove it?
Yup, I’ve watched several videos on YT, and each in each one there is a very loud rattle in the rear end. It seems normal. Not sure what it is
I didn't notice the noise at first only later when I was home with the machine, so can't definitively say it wasn't there. I tried looking on YT too but couldn't find a video where I could clearly hear the rear end over the engine noise. Which one did you look at?
/ New owner Kioti CK 2610 HST #14
Don't sound good, but make sure it's not just something rattling....rops, smv sign bracket, lots of stuff rattles on my Bobcat near back end, and rattles change with changes to what operator is doing with machine.
My ct2025 hydrostatic, essentially a Kioti, has clutch pedal. Used to select speed range as well as pto. Normal thing.
hi, its definitely in the rear end, just trying to figure out if that noise is normal before I retake possession of it. Isn't the ct2025 the same machine? Do you notice a noise like the one in the video?
/ New owner Kioti CK 2610 HST #16
Listen from 9:00 to the end… Unless the engines are really that noisy? Every video I watch of this unit has a loud rattling noise.
/ New owner Kioti CK 2610 HST #17
i have the bobcat version with 105 hours. I will check tomorrow when doing chores, but i do not recall hearing any sound or vibration difference with clutch in or out. And FWIW you only need clutch to start (safety) and use the rear pto. no need when shifting ranges.
thanks, that sounds like the engine noise, they are quite loud, when throttled up it will drown out the rear end noise.
thanks appreciate it.
/ New owner Kioti CK 2610 HST #20
Ok. Mine sounds like a vacuum cleaner, without any mechanical clatter, so I was unsure if that was the engine or not.
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
HYUNDAI HL955 WHEEL LOADER (A62129)
HYUNDAI HL955...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
500 BBL FRAC TANK (A60736)
500 BBL FRAC TANK...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
