Nice little beginner welder
/ Nice little beginner welder
Just a little side note, I did not get whats in picture, the plug coming out of welder was the 220volt plug and they gave a 120 volt adapter, that's how confident they are in their product , they want you to use it to max settings, I only used it for 120volts, burned 1 pound of 5/64 rods
Just the adapter is 80$ on amazon
I did not try it higher than 80 amps only used it on a 15amp breaker , Got a generator 4000watt peak 4500 but not sure if safe.
Lets talk a little about generators :) ran into this issue like 10 times in the last 2 years on friends rigs, The plunger under carb that shuts the main jet, just cut it, My cub caddet mower is new so after warranty runs out its going to get cut as well, good night
Don't forget to shut tank if travailing with it or gas might get into base, later
/ Nice little beginner welder #8
I've run my Harbor Freight Titanium MIG 170 on my Champion 4kw generator with flux core, with what you are running I would imagine you would be fine, I stalled the generator a few times before I found the right setting :)
/ Nice little beginner welder #9
I'm no pro... I mostly weld AC , but bought this welder last year and impressed, I built a sand racer(2000 hours) and a 6 inch lift on a ATV
I've seen good reviews on the Tooliom welders.
I think the time has finally come when really inexpensive welders from China are at least HF quality at minimum, and considerably less expensive than HF for comparable features. And prices are dropping continually.
I see only $15 additional to add a 4 year warranty on the $99 195 amp version. That's crazy cheap for 4 years of use!
/ Nice little beginner welder #11
Ya or buy two for parts
And because of the warranty, you can wait 4 years before you need to buy that spare.
Maybe the spare will cost even less, by then!
And buying that will start another 4 year warranty. What's not to like? :)
/ Nice little beginner welder #12
Given how Chinese companies come and go will they even be there should you need to use that "warranty"? Of course, for that price you could just toss it if/when something breaks and still come out ahead.
One of my first welders, clarke 131e arc welder 120v, 130 amp, Alot stronger than my 120 volt lincoln mig welder
/ Nice little beginner welder #14
I called the unrelated company offering the extended warranty when I bought the similar Amico FC welder. It seemed too good to be true. They said the warranty includes replacement with something comparable if that's what it takes for you to have continuous service.
And I asked if they had many warranty claims on the cheap welders. She said rarely. She could have said lots of them fail so I need a warranty but she didn't say that.
Bought a 1990 TRX300 like new with nipples still on new tires, A lady flipped it and cracked front fender, Heated garage stored, Got it for 2600$, Anyways im going to try and weld it this way.
Or new fender 500$
The clutch basket and crank gear of the trx300 can fit on a honda 400-450 and I think 500, not sure, It lowers the gear ratio 35%
Nice score. Did you “weld” that plastic yet? I’m curious about how the plastic welding works out. My old Grizzly has some cracked plastic, I have thought about the plastic welding for it.
Thanks,
Mike
No waiting for a nice day, Bought plastics once that had similar welds, Now I know how it was done
2018 Autocar ACX Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2018 Autocar ACX...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2004 Johnson 70hp 4-stroke Outboard Boat Motor (A66738)
2004 Johnson 70hp...
2009 FORD F-750 SUPER DUTY (A67714)
2009 FORD F-750...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
