Nice little beginner welder
/ Nice little beginner welder
My friend has this model , i'm going to use, Look at the tip options, This is canada amazon , you can get it cheaper
25 Watt 510C/950F , Hope its strong enough, he only uses it to burn wood, can use to fix computers aswell, I can build gaming computers and over the years through away pricey motherboards and vid cards, with only a burnt fuse i bet or a diode, might buy one
At 120volts Just tried 3/32 rods and at 100 amp setting burned a full rod and breaker tripped right at the end with a 15 amp breaker, thats about 2000watts, 20 amp breaker is about 2400 watts
Burned threw bed frames and thats kinda hard steel for 1/8 , great little welder , hope it lasts
/ Nice little beginner welder #23
The Tooliom in Post #1?
Yes, Im plugging in a shed soon so if I can burn 3/32 at 120volts il be happy, I got a 20 and a 30 amp single pole breaker I can use, tried it at a friends house today , wires in my walls are to small was scared to try, with 400 more watts with a 20 amp breaker i should be fine, im using 10 wire
TANK MANIFOLD (A67714)
IRON RHINO IR1000 Mini Skid Steer (A68134)
IRON RHINO IR1000...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
