how to build your own custom backhoe subframe
   / how to build your own custom backhoe subframe #161
Finally got the frame together. Took a big tree root out. I didn’t baby anything and it stood up nicely.
No flex. Pins work beautifully (I’ll report back if this changes over time)
Actually the tractor drives much better with this close coupled weight at the rear.
Big shout out to dfkrug for your help!
Happy digging folks.
   / how to build your own custom backhoe subframe #162
I do not know that hoe. Does it have a toplink connection under the seat? If so, I would connect that to the toplink bracket on the tractor for additional stiffness.
It is a good thing to see how much flex you get while digging. This takes 2 people; one operating the hoe, and the other looking closely at the frame at the rear of the hoe.
Looks good. Killer deal.
No engineered toplink per New Holland design, I can very easily add one though , if needed. Backhoe is 650 lbs per research. Feels solid so far. I am making cleats for the downrigger pads and will do some testing then.
   / how to build your own custom backhoe subframe #163
Tested today, a little more flex than i liked. Adding toplink, tractor to hoe.
   / how to build your own custom backhoe subframe #164
Tested today, a little more flex than i liked. Adding toplink, tractor to hoe. Please disregard tacks. Will be looking nice soon.😁
Toplink did the trick. About 3/4" flex back is gone now. If not already mentioned, i believe proper bolt connection clearance holes are very important.
Good job.
The holes in the half-inch plate I used for the subframe on my Kioti CK30 were for 1" fine-thread bolts. I placed them fairly precisely, and as the hours built up, the tiny flexes and wiggles eventually caused the bolt threads to bite into the plate a bit. Now, the bolts do not just slide right in or out.
So, more clearance (bigger holes) may help with that, but they would also allow more movement. I used nylock nuts and sometimes lock washers, too.
Tradeoffs.
   / how to build your own custom backhoe subframe #166
Hello everyone, new to this forum! I have a 1988 Ford 1720 with 7108 FEL and a Woods bh750-2 mounted by the 3 link. I want to swap out the 3 link for a subframe as I really don't want to take any chances with anything cracking or breaking. Obviously all the bh750-2 stuff is far out of manufacture and most of the 1720/757b stuff. I have been searching and im finding newer '96-'06ish 1920 subframes that were used with the 757/8c backhoe on the 1920. Im curious how close the frame is between the 1720 vs the 1920? I will fab up some brackets for the Woods BH and whatever else is needed. Does anyone have any comparison measurements possibly of the 1920? I would greatly appreciate it. Also I wonder how different the Woods bh7500 vs the bh750 are?
   / how to build your own custom backhoe subframe #167
@jayyk42 THANK YOU for reviving this thread!!! I would LOVE to find a 3point backhoe on FB marketplace but I refuse to use it on the 3 point. Finding a BH with a specific subframe for ones tractor is like finding a needle in a haystack. Buying new is PRICEY and I'm cheap. Making a subframe seems like the way to go. Have not yet read this whole thread but it seems like a wealth of knowledge on the subject.
Also thanks to @dfkrug for starting the thread and dropping all of this knowledge!
   / how to build your own custom backhoe subframe #168
I'll also add to this thread.
I was given an old pre MF backhoe. ( Mid Western Industries ) MF bought out Mid Western to start their own industrial line up. I need to attach this onto the FEL frame on the MF 165 that I also had given to me. I just need to get the 165 running. The injection pump needs to be rebuilt. I'm not in a rush to get this done so it'll take a while.
One of the differences between the old Woods 750 and later 7500 models is that they went from a single-cylinder chain-type boom swing to a 2-cyl system. Buckets and prob even subframes should work on both.
My own clone hoe (Prairie Dog 7.5) is a beefed up 7500.
Those older 1720/1920 Ford/NH tractors really do need to be protected from breaking in half.
Backhoe attachments for CUTs have lost a lot of ground to mini-excavators, esp the cheaper Chinese units. You can find them all over Craigs and MktPlc for reasonable prices now. A new hoe attachment plus subframe will cost more than a 1-ton mini-X as long as you stay away from pricey name brands.
I love my 1-ton mini-X, but the backhoe attachment, which is always on my tractor does have its place. It can reach farther/deeper and the greater weight allows much greater forces to be applied. The 1500# ballast to my Kioti is especially useful for lifting/pulling logs and other heavy objects.
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
